FiiO M11 Plus or M11S would be the closest. Both have similar design language to the BTR7 but sonically the M11 Plus would be the closest due to its THX AAA-78 amps
Oooof, the S is more than triple the BTR7 and the Plus is more than quadruple it :/
Suddenly, the BTR7 feels like a bargain... Was thinking of returning the BTR7 and getting a DAP to make my entire music situation simpler (currently copying all my music across 3 devices) but if that's the cost, I want none of it xD
I'm gettin a splotch of white pixels above the volume occasionally that only disappear when I turn the btr7 off and on. Anyone else getting this? Wondering if it's a firmware issue or whether should I return and get a replacement? @FiiO , Input appreciated . Will post a photo next time it happens
@FiiO, I don't seem to be able to find these numbers published: what is the power output at 600Ohm via BAL? Ideally, both in mW, Vrms and mA? It would be also good to see those numbers with the BAL boost enabled.
