[FiiO BTR17/BTR7] True Lossless Bluetooth, Portable Bluetooth DAC and Headphone Amplifier BTR17 Is Officially Released!
Nov 21, 2024 at 4:59 PM Post #2,268 of 3,460
same same, really odd.
I just did a factory reset and now AAC is there. This device seems to be very buggy.
AND IT FIXED THE BT VOLUME. Incredible. Now I cannot go above 35 anymore, it gets too loud as expected.
Nov 21, 2024 at 5:47 PM Post #2,269 of 3,460
I hope fiio can replicate and fix this issue, if my Btr17 doesn’t get to volume and I’d have to factory reset it every time that’ll be pretty annoying
Nov 21, 2024 at 5:48 PM Post #2,270 of 3,460
So far so good, I power cycled a few times and it's holding.
Looks to be a bug.
Nov 21, 2024 at 5:50 PM Post #2,271 of 3,460
From earlier impressions at an audio show in Canada it looked like that was a complaint amongst the people who demoed the Btr17
Nov 21, 2024 at 6:00 PM Post #2,273 of 3,460
the factory reset fixed the LDAC and BT volume issues for me as well, not the LE Audio though. I hope it lasts.
Yeah same, I don't really care about LE audio so it can wait.
Edit: a new issue seems to be intermittent faint crackles and pops. Aaargh!
Nov 21, 2024 at 6:09 PM Post #2,276 of 3,460
I hope that someday fiio can have software AS good as Qudelix. That’s a solid company with amazing software support.
Nov 21, 2024 at 9:34 PM Post #2,277 of 3,460
Yeah man, just wait for the Firmware updates. I got lucky with only some initial buggy codec selections. Volume is solid.
Only complaint remaining @FiiO-Yellow is the length of custom names being way shorter than the BTR7 ;)
Nov 21, 2024 at 10:26 PM Post #2,278 of 3,460
So your experience is the opposite of mine, in my case the BTR17 is quite less loud than the BTR7.
Edit: it gets louder when connected to the PC and PC mode is on., it seems to be quiet in BT mode.
@FiiO does the BTR17 output less power in BT mode than BTR7? Seems to be the case. Can you share what the power output is in BT mode? Thank you
Hi, BTR17 output power in BT mode is similar as BTR7. BTR17 output power in BT mode is 300mW, but BTR17 has more potential.
Nov 21, 2024 at 11:02 PM Post #2,279 of 3,460
Thanks, a factory reset fixed my problem.
@FiiO any imminent firmware updates for the BTR17? It's quite buggy
