tret
If you're on Android, you should be able to specify call and/or music in the BT menu screen for the BTR5 device.
Have an iPhone, sadly.
I don't have an iPhone but it seems like you can only set it either to default to Bluetooth or the phone speaker:
https://www.iphonelife.com/content/how-to-set-your-speaker-or-headphones-default-audio-iphone
Anyone tried BTR5 with Senn IE800?
Are you listening connected to the BTR5 2.5mm or 3.5mm output? The limiting factor for driving power hungry headphones is the power output of the BTR5 on 3.5mm vs the 2.5mm. I found moving to the 2.5mm output on the BTR5 makes a bigger difference for power hungry devices.Just received my BTR5, good first impression with Sony MDR-EX650 and Fiio FH1. However less so with the IE800 which I find a bit dark sounding fed by the BTR5. But also on other amps the IE800 is not my first choice nowadays.
2.5mm balanced male -> 3.5 balanced female adapter That is a way to BURN device
2.5mm balanced female -> 3.5 balanced male adapter That is proper way to use balanced headphone on unbalanced devices
Yes it is OK to convert balanced headphones to unbalanced device .If i buy hidizs sonata ii hd and my iem's are 2.5 mm it's ok to use an 3.5mm to 2.5mm adaptor ?
The benefit to converting IEM's that come with 3.5mm unbalanced cabling to 2.5mm balanced cables are audible, especially with the BTR5 that has higher power out of it's balanced 2.5mm output.Yes it is OK to convert balanced headphones to unbalanced device .
It is not advised to convert balanced device to unbalanced headphones (it might work, but is risky and gives no gain vs unbalanced output)
I’d check out Zynsonix dude. Bryan from there made me a balanced cable to go from my Audeze LCD-2’s to my HiBy R6 Pro. It’s beautiful and the sound is amazing. They could prob make you what you want
Thank you both very much for the recommendations and please excuse the late reply, I do really appreciate the help!Connected to my surface pro, the range of the BTR5 is even worst on aptx compared to connection with my V30 on Ldac.
When a second device is connected to my surface, my logitech MX Master for example, the music starts to interrupt from time to time.
Seems that the bluetooth device in my surface pro is the weak point here.
Never encountered such flaws with the BTR5 connected to my V30.
I am thinking of upgrading to the 5 from the 3; Can you talk a little about the sonic diffrences? Thanks.I have my one for a month now and it is still crystal clear. You don't know what type of plastic it is made of. It's not one of those cheap rubber/silicon phone cases that turns yellow after couple of weeks. I have both Btr3 and Btr5, and design of Btr5 is excellent. The good thing about removable clip is that if you brake it, you can just get replacement without sending the whole unit for repair.
A review should include less detail about your feelings and lifestyle, and more detail about sonic characteristics.Hi all, for anyone interested I've written up a review of the FiiO BTR5 with a comparison to the Q5S. You can read it on my website here: https://www.modioaudio.co.uk/blog/fiio-btr5-its-spunky - please let me know what you think!
I'm using my btr3 with my custom Valkyries and they sound fine, if it helps...Maybe the Btr5 doesn't handle this extremly low impedance ciems ( 3 ohm ) very well.
Too much current needed?
Sadly i'm not able to reproduce your behavoir bc i don't have such low imp earphones.
Is this happen with usb connection to the Btr5 too?
Is it on SE or balanced?
