[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
Jun 20, 2022 at 6:00 AM Post #3,031 of 3,639
It also works with Onkyo HF and Hiby Music App - no PC needed for files downloaded directly to the Phone.
BTW, on Hiby, dff files were displayed as DSD on the BTR5 while dsf files were downsampled to 88khz pcm. It is an app problem, I suppose?
Dear globobock,
1. You could try the Wifi transfer function in the FiiO Music app as well.
2. You could check whether there are any setting int the app may lead to the issue? And also check via other dsf file.
Best regards
Jun 21, 2022 at 3:54 PM Post #3,033 of 3,639
Dear globobock,
Best regards
Forget it, it works with my fire hd 8 :)
BUT … it plays up to DSD128 with Fiio Music, but it won‘t play DSD256 files.
Is there some settings, either on the Fiio App or the BTR5 that I got wrong?
Jun 22, 2022 at 5:47 AM Post #3,034 of 3,639
Dear globobock,
Yes, the FiiO Music app ios version could only support up to DSD 128. You could check whether there are other app supporting DSD256 native output in iOS device for help?
Best regards
Jun 22, 2022 at 5:50 AM Post #3,035 of 3,639
Dear globobock,
Best regards
Hi no it is not the iOS version, this time I am using the Fiio Music App for Android (from Google Playstore) on the Fire HD 8.
It is also a limitation by the app then, good to know.
Not that I plan to listen to DSD in the future, I just wanted to test the capabilities of the BTR5.
Jun 22, 2022 at 9:40 PM Post #3,036 of 3,639
Dear globobock,
Please try to switch the DSD output mode to 'native' in the USB output menu of the FiiO Music app, then try to connect the Android mobile phone to the BTR5 again:
Best regards
Jun 23, 2022 at 4:16 AM Post #3,037 of 3,639
Dear globobock,
Best regards
Thx I'll try it.
BTW., the USB-C cable is just too short, I'm looking for longer cables. Can we use just any USB-C male to male cable?
Jul 11, 2022 at 6:55 AM Post #3,040 of 3,639
Hi, anyone experiencing bug with "beta" BTR5 firmware here? In Android Tidal Exclusive mode I am not often able to play any song (same behavior like very slow loading, but even for offline downloaded albums so definitely not connection issue). It works immediately when BTR5 unplugged - no fault message appears so nothing to mention here. Happens very often. Source Samsung S20FE 5G.
It also makes pauses when switching apps on my phone so it seems that returning to UAPP will be better idea than trying to use Tidal app :frowning2:.
Is it possible to revert XMOS firmware back so Tidal would not fight with UAPP for exclusive mode anymore? :-D
Jul 11, 2022 at 7:31 AM Post #3,041 of 3,639
Will try to test it later,
How about bluetooth? Any issue?
Jul 12, 2022 at 5:05 AM Post #3,044 of 3,639
Dear inkvizition,
You mean BTR5 or BTR5 2021? For BTR5, it does not support MQA. So you may need to switch the straming quality to HiFi in Tidal app.
Best regards
