With the Tin P1 the Btr5 sounds magical...
Thanks to this forum and to all of you for this kind of emotions...
Oh, yeah, that's right, silly me. Thank you @Ichos.It is adjusted separately so you need to check out the level.
Sounds like maybe that's a charging only cable. As far as I understand, USB-C doesn't require OTG like older versions of USB. Any proper USB-C cable should work.Hey all, I wonder if anyone could help me with an issue I have with my brand new BTR5 which I enjoy immensely so far...
When I connect it to my phones through USB with the usb-c to usb-c cable that came with my Pixel 3a it works just fine. But the plugs are a little loose and with the slightest move it disconnects from the phone (especially on my older Xiaomi MiA1 which is a bit worn-out). So, I tried another usb-c to usb-c cable from Baseus, a Type-C CATKLF-G91, 3A 60W, PD2.0 which I have used for some time now to charge anything usb-c and is tighter... But, it doesn't work. BTR5 doesn't recognize it and phones play from their speakers instead...
Could there be something wrong with the cable or are specific usb-c cables needed to work and Google's is one of them?
Well, Baseus says it's also doing data, so...Sounds like maybe that's a charging only cable. As far as I understand, USB-C doesn't require OTG like older versions of USB. Any proper USB-C cable should work.
Maybe an Anker or a Samsung cable proves more durable... I am planning to get a Samsung when I go shopping in town. I have a 25W PD charger for a few months now and seems pretty good quality.i have 2 Baseus 65 Gan chargers, the one i have at home works great,
the one i have in the office, 2 months in the PD 3.0 port is dead, not very nice for a 40 buck charger.
FiiO Usb dac driverWhere i can get the windows 10 drivers for Btr5?
Can you share a links, i don't find the drivers on the fiio website...
Thanks
Do we know if Fiio will be releasing a successor to the BTR5? BTR5K? I've got a Qudelix 5K that I like, but it's sharp edges are kinda bothering me (small gripe, I know). I'm also a bit of a Fiio fanboy and love my FH3.
