Thank you for your attention and feedback for BTA30.
In order to make BTA30 more functional and cover more usage scenarios, we have tried our best to adjust hardware and software architecture . For this reason, it also led to serious delays in the project. Until it goes on the market, we are still optimizing the design to obtain more stable functions.
However, due to the limitation of chip resources, it is impossible to take care of every function. In the end, only most usage scenarios or requirement can be taken into account.
For example, LDAC LIB can support I2S format only, such as transmit from DSP through S/PDIF interface . It's a pity that BTA30's USB DAC decoded and transmit by CSR8675 itself!
We suggest customersl connect computer's optical interface to achieve LDAC transmission, which can achieve high-quality transmission and better compatibility than 48k/16bit.
Please refer to the following diagram about the signal path.
Regarding aptX LL cannot be dual-linked, there is not enough ROM space to support this function after implementing bidirectional LDAC, aptX, aptX HD and APP control.
Although the BTA30 is not the most perfect, it is still the most functional and powerful among similar products. The features can match the user's general requirements.
Of course, we will collect your feedback, and try to achieve more situation needs in the next generation or high level products.
Thank you.
