FiiO BTA30,Hi-Fi desktop bluetooth receiver&transmitter,RCA/Optical/Coaxial interface
Nov 1, 2020 at 3:20 AM Post #61 of 584
oh geez i wonder if there will be complications if i import from aliexpress to malaysia
maybe
Nov 1, 2020 at 11:32 AM Post #62 of 584
I’ve been searching for a way to transmit my record player output via ldac, and thought I had found the grail here, but I think not, sadly.
Is there another FiiO product that does the job, that is not a DAP?
Thanks!
Nov 1, 2020 at 2:43 PM Post #65 of 584
Thanks @Tano
I think I will try and get hold of one for the TV Box I have too come to think of it.
Look forward to reading your impressions!
Thanks, will do. It should be here in 3 weeks or so.
I think it can be a great purchase for the price, I've been lookin for ages for a product with those capabilities, only downside is the No LDAC transmitting while used as USB DAC, but still looks like a very versatile product.
Nov 2, 2020 at 1:44 AM Post #66 of 584
i might get one to use with optical on pc, most boards have optics put nowadays i think
my pc is at least 8 years old and still has optical
Nov 2, 2020 at 5:19 AM Post #68 of 584
Hi @FiiO
If the unit is plugged in to my computer via USB, can it output the digital signal via Coax to another device?
Thanks!
Dear friend,
Yes.
Best regards
Nov 2, 2020 at 7:37 AM Post #69 of 584
Nov 2, 2020 at 9:29 AM Post #71 of 584
Hi @FiiO
Can you please confirm:
  1. Is dual-link AptX-LL with two AptX-LL headphones something that could be implemented in firmware in future? (You previously stated that the BTA 30 WOULD have this capability)
  2. Is LDAC transmission when using USB-C audio input something that could be implemented in firmware in future?
  3. Are either of these things being looked into?
Nov 2, 2020 at 9:45 AM Post #72 of 584
Hi @FiiO
They replied me for the 2nd point with:
"Yes you can USB input BTA30 and transmit Bluetooth signal, but LDAC format isn't included.
Because there is a common technical challenge on LDAC waiting to solved."
"And is it possible you can solve it and add that feature later with a firmware update?"
"Sorry I have no idea about it yet."
Nov 3, 2020 at 5:34 AM Post #73 of 584
Yes, the codec library provided by LDAC for the Bluetooth chip(CSR8675) does not support USB in currently. So the LDAC Bluetooth codec is not supported when using the BTA30 as USB DAC and transmit Bluetooth signal. We are also trying to communicate with Sony for this problem now.
Best regards
Nov 3, 2020 at 5:35 AM Post #74 of 584
That's great to know. What's the best way to order one in the UK?
Dear user,
Or you could wait about 1-2 months to get one from the local seller in the UK.
Best regards
Nov 3, 2020 at 7:29 AM Post #75 of 584
Best regards
so the LDAC is only on receiver mode?
or can I do this ?
PC, usb to BTA30, bluetooth LDAC, fiio btr5, iem,
