skankhunt42
that is why I will never update mine they fix one thing, and break 250 in the process........
Hello Friend,Left it overnight, without power, and now it turns on in TX- and pairing-mode. (no freeze when switching modes either)
Strange... but can I trust this device, or should I return it to Amazon?
Will test more later today.
Hello, and thanks for answering.Hello Friend,
We found that some speakers or headphones, not pairing with BTA30, because the headphones or speakers pairing string is too long, resulting in BTA30 dead. Cell phone system compatibility is better, generally will not have a bad connection with the headset.
This is the headset or speaker design is not standardized to cause.
There are very individual headphones or speakers have this problem, some devices we have asked its manufacturer to improve, some have not yet.
If your headset and BTA30 connection will have problems, please tell us the model number, so that we can find the cause.
Thank you!
Check the app, and see if LDAC is checked under codecs.Hello,
I have received my BTA30 yesterday, plugged it to the pc via USB and Optical In. Tried to pair with my Sony WH-1000XM4 and all I got is blue light (SBC...)
Tried to plug the USB directly on power instead of PC and let the optical connection between PC and BTA30, and still blue light... I can't get white light (LDAC)...
Am I doing something wrong?
ps: I have upgraded the firmware.
Wow I didn't knew there was an app!! Thanks, I'm going to check that!Check the app, and see if LDAC is checked under codecs.
FiiO Control app.Wow I didn't knew there was an app!! Thanks, I'm going to check that!
edit: just to be sure you are talking of BTA30 app, not Sony's headphones app?
FiiO Control app.
You need to set the BTA30 to RX mode for connecting to your phone.
You use optical spdif from your computer? Try to change the output from your soundcard, to 24bit/96khz. Maybe the BTA30 use lower codec, because you use 16bit/44(48)khz?Thanks!
LDAC is enabled
in both RX/TX mode. I deactivated USB source, but still blue light when I pair my headphones...
Try to double click pair button to change codec once connected to headphones.in both RX/TX mode. I deactivated USB source, but still blue light when I pair my headphones...
HelloYes I used optical from computer. I set to 24b/96khz = same
I tried to double click, doesn't work, light is still blue...
And you could check whether you are connecting the Sony headphone to two device at the same time?Yes I used optical from computer. I set to 24b/96khz = same
