Dear friend,@FiiO what's the output power the btr3 and btr5 will be having?
We don't have this information currently. Stay tuned!
Best regards
Hello,Dear friend,
Best regards
Hello,
Do you know what will different/new in the BTR3? I'm trying to decide if I should get the BTR1 (V2) now or wait until June.
Dear friend,By the way, the situation of two new products.
μBTR,price about 15USD, CSR8645, aptX. (June)
BTR3,size like BTR1, price about 69USD, CSR8675, aptXHD, LDAC.
(June)
Dear friend,
This is some information mentioned by our engineer before.
Best regards
Yes indeed. I was one of the unlucky ones too who got a btr1 v1 old stock without aac support and not the v2 with aac. But I doubt they will mess this up again.@FiiO
Can you confirm that the BTR3 will have AAC codec for iPhones from the first day of release (as I have just sold my btr1 ad it only had SBC).
Thanks
Just curious - did either of you actually test the SBC volume matched against aptX, or against true aac (ie straight from your device)? When the discussion regarding missing Bluetooth transmission of aac with the BTR1 was going on, I decided to perform a little test. I volume matched and compared side-by-side with alternatives. I couldn't tell a difference in normal listening. I then looked up what the bit-rate for modern SBC standard was, and to my surprise its actually the equivalent of MP3 320!. Its no wonder I couldn't discern a difference.
And here's the point - if I can't tell in a quiet room at normal listening levels, how will I tell in a mobile environment?
Its just food for thought. Your own listening acuity may be far better than mine - and maybe you can tell a difference. But in my experience we often get caught up in the numbers without listening to what they actually represent. I'd still (like you) prefer aac be present for peace of mind. But I was genuinely surprised by the performance of SBC.
SBC is the equivalent of 320kbps? I was going to call BS on your Brooko, but since you're smarter than me, I thought I'd bettter double check. If the below source can be trusted, you are absolutely correct!:
https://www.rtings.com/headphones/learn/sbc-aptx-which-bluetooth-codec-is-the-best
Surprising but true!
MP3 is just a container/codec. What is important is that SBC can handle up to 328 kbps. The difference between an MP2 and MP3 is mainly compression. I also asked if you did a volume matched side-by-side test. I did. You didn't answer that - just gave the usual regarding individual discernment. I notice this a lot, and I'm not pointing any fingers. Everyone says they can tell the difference. No-one honestly tests themselves. Its not hard. Apparently almost everyone here has golden ears - I am one of the few exceptions. I'd love to see how many golden ears can really tell the difference when listening to normal music at normal sound levels, and aren't told which codec is which
Anyway, where SBC falls down is latency - not sound quality. AAC is supposed to be superior, and definitely is as far as latency goes - but sound wise ...... I'm not sure. Both, on my music, with portable use, at normal listening levels => sound pretty darn good.
Dear friend,@FiiO
Thanks
