H20Fidelity
- Feb 11, 2012
No problem with my Fidues and I use them to walk a couple of miles every day. So they certainly have movement near/at the connectors that has not caused cut-out. Manufacturing issues? Luck? Are people taking cables off and putting them back on, causing issues?
Again, if you have Fidues they will still be under warranty, so call the company and ask for help if you get cut-out. They may just replace the cable for you.
I don't think I'd like to spend the $ on 1 + 2s and have them fall apart in the street.
Haha, 1plus2 really are prone to falling off, wearing them round your neck (not in use) only to find one sides fallen off down the street somewhere 20 minutes later. Read a few horror stories. In fairness though it can happen to many customs using Westone 2 pin configuration.
