bfreedma
The Hornet!
- Feb 3, 2012
I believe I've done enough favor for armchair scientists. 5-10 samples with over 3db average and 12db maximum is convincing enough for me. Unless Fidelizer Pro customers request it themselves, I would rather spend my time on improving Fidelizer Pro for them.
And since when did I say Fidelizer optimizations is all about shutting down or manipulating non-audio stuff? Consumer user level never touch that.
Regards,
Keetakawee
WindowsX,
As you are well aware, a year or two ago I used software intended to identify system configuration change to identify exactly what Fidelizer alters and exchanged some PMs with you as I didn’t believe it was appropriate to release that level of detail about your product publicly.
While I can’t speak to the current version, the version I tested most certainly did manipulate non audio services, primarily turning them off or altering thread priority. There was one major concern I had that I communicated to you that clearly was both non audio and put you personally at risk of being liable for damage done to the Fidelizer user’s PC
In the version I tested, Fidelizer was silently turning off antivirus and anti malware software as part of its “optimization”. Or to be more clear, without asking the user if it was acceptable or even informing the Fidelizer user, your software was turning off virus and malware protection, leaving the system wide open to attack.
Should I run this test again and publish the results? Does Fidelizer still compromise Windows security as it previously did?
