So, if I am understanding this right, Fidelizer claims to improve sound quality because audio latency from your HDD to your DAC is reduced, basically? Or maybe the CPU usage would be less? In the former case, I cannot even think of a possible mechanism that this might improve sound quality. In the latter, I imagine someone will talk about EMI from the CPU and how it does something to imaging or whatever.
You are basically correct. The argument for better fidelity is that of intuition: the less activity in the system (outside of playing audio), then less "noise" that can bleed out of the computer. And once you include the definition of "noise that is not audible without music," their marketing argument is made. And subjective impressions of betterness pour in.
I have always asked them and myriad of other player apps to create any configuration as even the best case scenario to show any audible difference. They have not done so. But as it turns out, I stumbled on two using Schiit DACs. See:
https://audiosciencereview.com/foru...puter-activity-can-impact-dac-performance.22/
And from
https://audiosciencereview.com/forum/index.php?threads/budget-dac-review-schiit-modi-2-99.1649/:
There is about a 10 db difference in noise performance depending on what the computer is doing.
But here is the challenge: it is not clear doing less in a computer even if it results in less "noise" is audibly better! See all those distortion spikes? If I took away the broadband noise ("skirt") around them they would actually stick out better and be more audible!!!
In other words, chaotic response is your friend when it comes to distortion. Change that to deterministic tones and come and go in absence of any other noise to mask them and the results can be negative, not positive.
This is counterintuitive so not even thought about by these companies.
But anyway, did anyone do any null tests or any measurements at all ITT? I feel that these debates should be very easy to settle.
Null results are hard because timing of audio playback drifts over time. You can use audiodiffmaker to compensate but for me it crashes 99% of the time.
I vaguely remember people trying to capture the timing of audio samples and show a difference a few years ago but don't remember the details.
Outside of that, a simple test of two exactly configured system driving the Schiit Modi 2 DAC per above would be revealing of any such differences. I am open to doing the testing if someone loans me the two configured PCs. It is not worth it to me enough to spend my own money to buy that gear and put in the time to configure them.
