kundica
- Oct 4, 2015
Thanks Roy.I want to help resolve the issue with the ARC input. What source are you trying to play through the Wandla. The DAC can reproduce the PCM soundtrack of video programming but not the bitstream (AC3) encoded version that is the default setting for most sources. You may need to go into the devices menu and select stereo (PCM) instead of Bitstream (AC3 or 5.1).
Switching to PCM is the first thing I did. The C2 has the option to set the incoming audio on the other HDMI inputs to PCM as well, so I tried using a PC and a MacBook Pro after the internal apps didn't work. There is no issue taking PC or Mac sound through HDMI to the TV then using optical out of the TV to Wandla. I also tried a bunch of different cables in case they were being funny, but I can't get it working with this C2 at all. I still haven't tested our other TVs but I plan to try later today. My hope is that LG is doing something funny with the encoding rather than ARC not work at all on my DAC.
