I finally picked up a Wandla and have been tinkering around with all the setting and controls it offers. It has really taken the Bliss to another level and also made it not just a viable but a preferrable pairing with the Tungsten with plenty of headroom. The Bliss would run out of headroom when fed my the Soekris 2541 and the sound was more constrained compared to the Wandla.
I have a few questions that I am hoping someone can provide some insight on. Wondering if
@GoldenSound has tinkered with the Wandla enough to have some insight on this:
1.) What is the difference between the Volume (digital/analog) on the home screen versus the "digital input trim"?
2.) Does anyone know what voltage outputs are generated by the different digital input trim settings?
This review says that -8dB creates the standard 2v/4v output that most DACs output while 0dB is the max is 4.75v/9.5v.
3.) Would it be better to max out the amp and use the Wandla's digital/anaalog colume control instead? Is there even a difference?
The digital input trim setting seems pretty critical to synergize with the amp you are connecting to. It impacts both the sound and the range of volume control. As an example with very little testing I have found the Bliss sounds best with the digital input trim at -4dB and the DAC volume at max.
