I've heard with 300B it's a preferable design to have a tube rectification to retain the pure character of the 300B tubes.
Perhaps it should be OTL as well?
An OTL Design does not provide enough power for the likes of the Susvara and the Envy had been designed to be also a prrfect fit for hard to drive planars.Perhaps it should be OTL as well?
This is probably not uniformly answered as there are good and Bad rectification Implementations of both solid state and tube rectification methods.This is why I asked about Cayin HA-300.. There is also Modwright 300, Woo WA5 LE, A&S Agartha rv 2 300b are all similarly competent with planars. Just wondering if you go the SS rectification route if you gain bass performance at the expense of the 300B character. Tastes and preferences will obviously be different but would be good to know what the tradeoff are.
Nice.Our review of the new Envy is up! The headroom is good with the Susvara, the impedance switches have some real purpose here with planars best set to the 'hi' impedance setting. It also looks beautiful with those Fullmusic H300b tubes, no denying that.
https://headfonics.com/feliks-audio-envy-review/
Nice.
Did you manage to test with the Bartok and Meze Elites or Empyreans?
Thanks.Well for the Bartok we did a section on that as a paired DAC (Ring DAC). You can find that on page 2.
Elite and Empyrean sounded great with zero issues on load and tons of current headroom. Elite for me gelled well with the Envy's strong sub-bass response. However, Empyrean mids did exceptionally well with the Envy's sweetish overtones so both will be fine.
As ever, your DAC will have an influence on the exact final output.
Both options use copper wire.Remember the Elise has copper cables
and is slightly warmer than the Euforia in performance.
If you like that, stick with it and really buy a set of better 300b tubes.
I see 2 options on the Feliks Audio siteIf you have never heard one before, then the standard version will probably not be wrong to get a feel for it.
If you say you have a pair of 6sn7 sets, they might be able to do something.
But if the tubes could be deselected, which would have a noticeable effect on the price, then I would do it.
Then I would go to the Ofc cable and look for 300B tubes myself.
Get the new WE300B. They sound fantastic. Alternatively, the Linlai Elite is also good.I see 2 options on the Feliks Audio site
I am not sure what denotes 'premium copper wire' in the Standard Edition but surely it is at least OFC quality these days.
Yes, the Premium Edition uses UPOCC single crystal copper wire.
IMO I am paying for R & D, a great circuit and a really nice chassis and the wire is secondary.
I'll do my research and find a better pair of 300B than the EH Gold that come stock.
