UntilThen
- Jun 16, 2015
Good night? It's dim sum time for me.
Ok I google translate that. Basically he is saying that Elise is very good and to his surprise even sounded good on his low impedance TH600.
He also mentioned us - i.e the Head-Fi thread for reference.![]()
That is a Tung Sol 6F8G and I believe the adapter is from Feliks Audio because it's shown on their 2A3 amp picture on their website.
I've used 6F8G tubes with MrsX's adapter as a driver quite a few times in Elise and there's never any hums.
You lucky boi but don't you agree the other adapter is nicer?I'm really curious if FA actually makes that.![]()
Yes I agree it does look very stylish in that picture.
I've also been lucky with my present superb sounding set-up as it hasn't buzzed for nearly 12 hours, except when the wife walked in to water the flowers.
I think this is probably Elise at her best, for my ears, as long as it doesn't buzz.
Note the extra foil on the far right power tube anode connector-that makes a big improvement.
When the wife looks for the foil and there's no more, you're gonna be in real trouble !!!
Is that a EL11 in brown base?
Simple solution. Tell the wife not to walk around but she might come at you with the rolling pin.
Orientation is important. You must face the sun.![]()
You can tell I'm sceptical. I was about to post an impression of EL12N as drivers and EL12 as powers because it was so interference free but just as I was about to make the post, it started producing a groaning sound on my right headphone channel with no music playing. I thought I must have heard wrongly so I waited and listen again. Sure enough it came on again and thereafter at short regular intervals. This is getting spooky so I shut it down and have gone back to Figaro. I'll switch Elise to some other tubes later. I'm not sure what's going on. Is one of EL12 tubes going off? When I turn it upside down, I can hear some pieces of glass sound. However I am done buying more EL tubes.
Not even if I'm El Desperado !!!
The vibrations from your cranked up sub-woofer has probably damaged that tube. (only joking)
