scompton
- Jan 21, 2005
863-MJE340G and 863-MJE350G are listed as the alternates in the BOM I have.
Originally Posted by scompton /img/forum/go_quote.gif 863-MJE340G and 863-MJE350G are listed as the alternates in the BOM I have. |
Originally Posted by studeb /img/forum/go_quote.gif a brief update, i have grounded all the heatsinks, and the meter behaves, and there offsets are zeroed in now to hook it up |
Originally Posted by Emooze /img/forum/go_quote.gif I noticed the instructions state that the DMM will pull the bias reading down? Well I left mine on there for a bit and it stayed right at 580. Should I check this before I hook up any headphones? |
Originally Posted by pabbi1 /img/forum/go_quote.gif So, if I happen to have 1n5369b (51v, 5w - and yes, the leads barely fit), can that sub in for the 1n4757a? And, if I happen to have a 47v, 1w (1n4756a), are we still trying to get closer to 150v total, so 2x 51v and 1x 47v ok, or better at 153v for the z3-5 and z6-8 strings, respectively? oK, so Tanners was out of 1n4757a... |
Originally Posted by spritzer /img/forum/go_quote.gif If you go much above 600V then you will damage any of the Lambdas, Sigmas, 4070, Gammas and SR-003. Same probably applies to the SR-Omega but I'd never risk drivers which are worth their weight in gold (probably more) with anything but 580V. The HE90 and HE60 will also be damaged soon after 600V since since you are already pushing them at 580V. The SR-007 can take 800V without complaining but it's not something I'd recommend. |
Originally Posted by BoilermakerFan /img/forum/go_quote.gif What are the HE60s rated for? I do NOT want to blow Tachi's drivers via ignorance. |
