eXStata DIY Electrostatic Amp for Intermediate DIYers
Mar 30, 2010 at 2:52 AM Post #2,836 of 2,970
Yeah, probably...
BTW, anyone have an extra matched quad of fets? Might need them to help another build come online.
Mar 30, 2010 at 3:15 AM Post #2,837 of 2,970
Originally Posted by pabbi1 /img/forum/go_quote.gif
Yeah, probably...
I know i had atleast a couple of quads of the J271 but gf "cleaned" up the desk..so will have to match again. How soon do you need it?
Mar 30, 2010 at 4:13 AM Post #2,838 of 2,970
Couple of weeks out. Thank goodness my office is a 'no clean' zone. Once a year is plenty...
Mar 30, 2010 at 3:54 PM Post #2,840 of 2,970
I just wired my LEDs and to my surprise they did not light up ...
I have unfortunately used two different kinds of LED, 2 superbright and 10 standard LEDs.
(I wanted it the other way round but messed up the two bags with the LEDs...
But even the superbright LEDs are not bright enough.)
The standard LEDs need 10mA to light, so the power supply does'nt give enough current.
Could I increase simply that current with a parallel resistor? (parallel to the 75kOhms)
I don't want to remove the power supply again from the case.
Would that work with a standard resistor or would that also have to be a 5W resistor?
Mar 30, 2010 at 4:54 PM Post #2,842 of 2,970
Well mine don't ...
All LEDs are connected in series - the first and the last one are the superbright ones - which light up, all the others don't.
I just checked the data and the normal LEDs I am using here only have a brightness of 3mcd @ 10mA.
The superbright ones are made for 20mA operation and are really much brighter, think they are above 100mcd.
So I'll have to rise the current or replace all the LEDs.
Since installing and wiring took me about 2 and a half hour I'd like to try rising the current first ;-)
Mar 30, 2010 at 4:58 PM Post #2,843 of 2,970
Raising the current is going to generate an extraordinary amount of heat in the LED resistors.
Mar 30, 2010 at 5:10 PM Post #2,845 of 2,970
Well, if my (very dusty) physics knowlegde is right I'd have to lower the resistorvalue down to arround 30KOhms to get approx 10mA.
That will be a massive 3 watts dissipated by each resistor. Sure, a 5W resistor could possibly handle that heat...... but can the PCB underneath it?
When I was running the original 1.2W through the suggested 75kohm resistors, my PCB was hitting 120C. Not good.
Mar 30, 2010 at 5:19 PM Post #2,846 of 2,970
Sathimas, sorry about this, but in addition pulling 10mA from the PS at the filter caps will drop the voltage at the input to the regulator. I don't know how much offhand but you'll have to watch for thiss too.
I am surprised that your leds don't light at all at 4-5mA. Really surprised unless you are using super high current leds.
Mar 30, 2010 at 5:22 PM Post #2,847 of 2,970
I just checked the temperature (by finger) and the PCB is already quiet hot - so I'll just leave things as they are.
Thanks for your advice!
Those LEDs are just really cheap ones, I had to search a while to find the datasheet.
Something else - much more joyful: I just gave the offset/balance adjustment another try and this time it seems to work.
Maybe I just forgot to recheck the offset yesterday - i don't know...
Both channels are below 1V now since about one hour, I'll wait another one to be sure...
Mar 30, 2010 at 6:46 PM Post #2,848 of 2,970
Short notice
It's alive !!!!!
From this point one there will be only down and sidegrades in headphones :-D
Thanks again everyone here, especially Alex!
(I just somehow managed to bypass my pot with my loop-in/out circuit, I really have to rethink that wiring ^^)
Mar 30, 2010 at 8:06 PM Post #2,849 of 2,970
Originally Posted by BoilermakerFan /img/forum/go_quote.gif
Just imagine how good it would sound on vinyl via a Grado Gold or Denon DL103 cartridge on a modded RB250 tone arm in a modded Planar 3 TT through an AudioSector, TubeCAD Tetra, or Pass DIY Pearl2 phono stage.
Or a 'Colossus' TT w/highly modded RB-300, Zu DL103 and Pass DIY Pearl.
