- Aug 18, 2007
I didn't mean the BOM wasn't available, I just meant PCB + BOM vs complete kits (like the Spruce Canyon CTH kits).
Originally Posted by pabbi1 /img/forum/go_quote.gif As always, the really tough part is the case. |
Originally Posted by sergery /img/forum/go_quote.gif Hey TimJo, how are you finding the volume levels with your setup? I am thinking about setting up a vinyl rig and considering various phono stages. I am concerned I will end up with a weak source though. I am not a maths pro, but I calculate u feed the exstata something like 150 mV, which seems low, but I didn't know all of the impedances so this could be way off. |
Originally Posted by runeight /img/forum/go_quote.gif Hopefully those of you who DO have eXStatA builds are enjoying them because we don't know when we'll get back to this. |
Originally Posted by runeight /img/forum/go_quote.gif ...it would seem from the posts, quite a few folks were encouraged to try stats as a result of this amp's availability. |
Originally Posted by pabbi1 /img/forum/go_quote.gif ...actually, this is one of the easiest builds to source, even without a pre-populated kit. Matching the FETs is probably the hardest part. As always, the really tough part is the case. |
Originally Posted by sergery /img/forum/go_quote.gif Yeap. And the more I look at it, the more I realize I am probably going to give the amp a few coats of paint and get a custom front panel from FPE. Never done the latter, how much does something basic run, can someone give me a ballpark idea? I feel like the amp deserves a better home. |
Originally Posted by TimJo /img/forum/go_quote.gif It's kinda feeling like it is a reference amp in it's neutrality. But this also makes it a bit unforgiving, even to recording sessions. Well recorded and well mastered albums are better than I've heard them, but on the other hand, poorly recorded or poorly mastered recordings are now much more obvious. Not a bad thing. It just makes you better appreciate the good stuff. |
Originally Posted by Beefy /img/forum/go_quote.gif Just download the design software, make something, and it tells you how much it costs |
Originally Posted by luvdunhill /img/forum/go_quote.gif Has anyone tried Cam Expert's new design software? Front Panel Design and Fabrication Custom Front Panels |
Originally Posted by Beefy /img/forum/go_quote.gif It looks like the most gap you could get away with around the Stax plug is 1.5mm around the radius and 1.5mm depth. MAYBE 2mm in either dimension if you push it? I would be interested to hear other people's thoughts on this...... |
Originally Posted by cfcubed /img/forum/go_quote.gif Dude, deja vu for me WRT b22/HF-2s - see OT: Forte comment. A bit OT, but would not be without a fun/forgiving combo & a reference combo. Perhaps other stats would get you closer to having both in one. |
Originally Posted by luvdunhill /img/forum/go_quote.gif Looking at my notes, I was planning 1.5mm radius. I'm not sure why the depth would be limited, so I'll have to think about that. I'll remeasure tonite though. |
