ericj
- Aug 2, 2005
There are indeed any number of ways to skin that cat, and yeah, tacking on another voltage divider is one of them.
In the basic configuration you have one bias voltage under about 360v and another bias voltage over about 360v.
So if you just have regular and pro bias stax, set the low one to 230 and the high one to 580 and you're set.
If you had low and high bias stax and an esp950, just use 580 for the esp950 too. Or maybe set it for 590. This isn't many volts difference so it's perfectly ok to just be in the ballpark. I doubt many commercial amps are right on the nose of their stated bias voltage anyway.
It's the guy who wants to drive his ET1000, normal bias stax, HE90, and pro bias stax all at their factory specified bias voltages who has to get creative.
Edit: I really should staxify my Stagnavox this weekend and try it out on the eXStata. Those are, what, 200v originally?
Originally Posted by spritzer /img/forum/go_quote.gif You can also just setup the HB supply for a given value and then use a high impedance voltage divider to get any voltage you'd like. It's just 3 resistors so very easy. |
