On my phone app in the streaming area if you scroll to the bottom and select DLNA it will open a guide to explain how to get it to work.Nobody? I try to open dnla streams, but the button in the eversolo phone app doesn’t open up dnla streams?
Eversolo DMP-A6 Network Streamer/DAC
- Thread starter PopZeus
jcn3
what are you using for a dlna server?
jjazzy
Serviio. I can connect to it already for years, from Vlc, ifi zen stream, my astell &Kern music player, two tv’s in the house etc… in the zen stream I just open the app and open the dlna folder and play, and walk away sort of, even close the ifi app itself.what are you using for a dlna server?
The eversolo shows me some weird screenshots? when I go to music connect? In the app. At least it does not show me dlna servers on the network?
If they are trying to explain me I have to cast, then I call that no dlna support to be honest. I hope I am doing something wrong.
jcn3
so you're opening serviio and you cannot see the dmp-a6 as a endpoint, correct? according to the web site, the dmp-a6 definitely supports being an endpoint for a dlna server.
jjazzy
I meant the other way around. Why would I do it through the web portal of serviio. My tv just connect through a browser to files shared from my serviio server. The same as astell and kern music browser, or android usb playerso you're opening serviio and you cannot see the dmp-a6 as a endpoint, correct? according to the web site, the dmp-a6 definitely supports being an endpoint for a dlna server.
pro etc…
When I do that with the eversolo app, and open dlna, I get to see 4 screenshots? Instead of opening my shared files from my serviio dlna server?
You see it properly. Browsing of DLNA server content is not implemented neither in the Eversolo Controller app nor in the DMP-A6 GUI. Perhaps you could propose/request this use case to Eversolo for implementation.I meant the other way around. Why would I do it through the web portal of serviio. My tv just connect through a browser to files shared from my serviio server. The same as astell and kern music browser, or android usb player
pro etc…
What you can do is to use another controller app, like BubbleUPnP on Android or Mconnect on iPhone. With those ones you can browse your server content and stream it to the Eversolo as DLNA endpoint.
jjazzy
Where would you request that? Because. For as I know almost every brand supports it? Browsing a dnla server?You see it properly. Browsing of DLNA server content is not implemented neither in the Eversolo Controller app nor in the DMP-A6 GUI. Perhaps you could propose/request this use case to Eversolo for implementation.
Charles C
- Oct 3, 2009
can someone pls post a photo of the eversolo a6 screen when using tidal connect does it show the album art etc? many thanks
It shows everything
Tidal Connect is the worser way to sream with a6 - use the a6's direct functionality! It replays quite better.can someone pls post a photo of the eversolo a6 screen when using tidal connect does it show the album art etc? many thanks
Why ?Tidal Connect is the worser way to sream with a6
What does "direct functionality" mean?use the a6's direct functionality!
Because one guy said so in YouTube
So there is Tidal connect and then the built-in Tidal app in the Streaming area. Try A/B testing.Why ?
Use the built-in functionality from the Streaming of a6.So there is Tidal connect and then the built-in Tidal app in the Streaming area. Try A/B testing.
I'm searching for ways how to turn DMP-A6 to a Chromecast device. I found an app called CastReceiver and it works, but it's a (5 minutes only) trial installation and there's no way how to buy the app.
Is there any other app which you could recommend..?
(See screenshot with a video played from youtube (PC). However, audio streaming would be fully enough for me...)
Total: 7 (members: 0, guests: 7)
