Eversolo DMP-A6 Network Streamer/DAC
Oct 14, 2023 at 1:50 PM Post #241 of 1,443
where did you got the update? doesn't seem to be available yet in Europe.
Turn off - turn on here it comes.
Somewhere I saw the internal update app, but laziness wins.
They bought me with this spectrum mode.
I wanted to do some comparison between the two streamer (the Rockna has to go back soon) but I somehow just cannot switch source. It seems I like purple... Especially when it is Deep ☺️
Oct 14, 2023 at 5:56 PM Post #243 of 1,443
New firmware doesn’t seem to be available yet in US. There is also a setting to install beta firmware but I won’t do that, would rather stick with official. Tried turning the unit off and then on again same stuff. Tried checking the box for beta same result “software is up to date.” Any advice?
Edit: they apparently on their forum said that the firmware would be rolled out in stages. I actually just recommend people go to their community forum and download the zip file. I got it installed off my NAS drive through the Eversolo gui using the usb upgrade feature.
Some things I like: internal player playback screen now has themes. Nice. Spectrum is actually in line with the music playback which is nice. They fixed the keyboard input on cast for searching in apps with improved functionality. They apparently have given up on the spectrum and vu meters though for optical input from my tv it just shows a huge volume level on block letters now if you enter the top right cd or record icon while using a non streaming physical input like optical.
Oct 14, 2023 at 6:59 PM Post #244 of 1,443
v1.2.10 is available in the US (at least South Carolina). Just updated.
Oct 15, 2023 at 2:38 PM Post #246 of 1,443
Apparently upsampling was enabled in the latest firmware. Just go into settings > audio > fixed sample rate output. Didn’t see anyone mention this on zidoo. It will show the original track data rate and sample rate and bit depth below the artist name and then below that will show the upsampling setting. I assume when it says 192 it means 192/24.
Oct 15, 2023 at 3:37 PM Post #247 of 1,443
Upsampling always there as long as EOS mode turned off, has been the case since the beginning
Oct 15, 2023 at 9:42 PM Post #248 of 1,443
Yeah I think you’re right about that. I’m not sure what some of us were getting wrong but disabling EOS engine and selecting the output rate does seem to make it work.
On another note one of my favorite streaming radio apps has most of their channels embedded in the internet radio section of the radio player app. I can find a lot of Soma FM content rather that going through airplay on my phone and draining the battery. Also even a lot of my cities’ local radio stations are available that normally broadcast on FM radio. Really am loving this device. 👍🏻
Oct 15, 2023 at 10:28 PM Post #249 of 1,443
I've been listening to Fiona Ritchie and the "Thistle & Shamrock" show since the 1980s, when it was over-the-air on National Public Radio stations. It's convenient that SomaFM now streams it wherever there's Internet.
Oct 17, 2023 at 6:01 AM Post #250 of 1,443
Can PC-Audio via USB-C in be paththrough to USB-A or S/PDIF out?
Oct 17, 2023 at 6:10 AM Post #252 of 1,443
I was asking a similar question recently (although, I was wanting the signal to go the other way - S/PDIF -> USB), and the answer is that the firmware only supports digital outputs from the internal audio player or streamer apps. Any external digital audio input can only be output via the analog connections.
Oct 19, 2023 at 12:28 AM Post #255 of 1,443
so it seems that DMP A6 software doesnt have EQ, but can someone confirm whether Roon or audirvana apply EQ to the music files played through DMP A6 as a streamer?
