Thanks for your very nice post. It helped me to go to the ER3SE. I come from beloved HF5, then went to the amazing ER4XR that I quickly sold though for some reasons. Enter the ER3: finally, I went to the SE and am glad I did. Well balances, quite neutral but sounding wonderful. I can see the small gap with the ER4XR if really thinking analytical, but without A/B listening both are just so good.
Etymotic ER3SE & ER3XR?
- Thread starter barihunk
Killcomic
Is it just me or is the ER3XR boomy and veiled?
Not offensively so, but in some songs with deep male vocals, it certainly feels that way.
441879
- Dec 21, 2015
not in my experience, but like all iems, fitment is critical. If you aren’t getting a very high level of isolation from outside noise, that’s a good sign you don’t have a good fit. I use westone silicon tips with mine, which deliver exceptional sound and isolation with pretty decent comfort
Killcomic
I thought it was the fit too and spent an entire day trying to sort it out with no improvement.not in my experience, but like all iems, fitment is critical. If you aren’t getting a very high level of isolation from outside noise, that’s a good sign you don’t have a good fit. I use westone silicone tips with mine, which deliver exceptional sound and isolation with pretty decent comfort
Then, I figured out what it was. You're not going to believe this. It was the audio player I was using on my iPhone, jetAudio!
I swapped to another player and bang! Problem solved!
I think it has some sort of DSP running that lowered the upper mids and treble, and boosted the mid bass.
Now everything sounds great!
441879
- Dec 21, 2015
glad to hear you worked it out.
Killcomic
Not as glad as I am, I can assure you!glad to hear you worked it out.
Now I’m just trying to get used to the sound which sounds very different from what I’ve had before.
Interesting. In a general note I'd say these ER3xx have slightly less consistency (based on very limited samples tested) than the ER4(XR) I had the pleasure to use for 6 months. But once you have a good one it should last consistently.
Killcomic
Oh? In which way are they inconsistent? Like they sound different from one unit to another?Interesting. In a general note I'd say these ER3xx have slightly less consistency (based on very limited samples tested) than the ER4(XR) I had the pleasure to use for 6 months. But once you have a good one it should last consistently.
The sound signature is the same but my ears feel the output is slightly different. YMMV
Dobrescu George
Reviewer: AudiophileHeaven
I made a full written review about the Ety ER3SE, hoping it could come in handy for everyone
https://www.audiophile-heaven.com/2021/05/etymotic-er3se-iems-deep-connection.html
