The Ethernet cables, Switches and Network related sound thread. Share your listening experience only.
Apr 18, 2021 at 6:23 AM Post #421 of 2,189
Now listening with the original power suplys again to router and switch to be sure it was not placebo.
I agree, It's not :)
Going back to stuff that performs worse can be painful :L3000:
Apr 22, 2021 at 4:15 AM Post #422 of 2,189
I havent figured out yet if cleaner power for router somehow can improve the sound with wifi. Maybe time will tell with more normal listening/viewing. I only use wifi for my oled tvs internal streaming apps though.
Apr 22, 2021 at 5:32 AM Post #423 of 2,189
Do you stream music via wifi, or do you use it only to control your streamer device with files stored somewhere?
Apr 22, 2021 at 5:38 PM Post #424 of 2,189
I only use wifi for my oled tvs internal apps like netflix, youtube etc. Optical out to hugo 2. I control my streamer with smartphone that uses wifi of course. Tidal connect. But my music streamer and apple tv 4k is wired Ethernet.
Apr 25, 2021 at 4:32 PM Post #425 of 2,189
Recently I got feedback from one our customer who uses a router to provide wireless control for his streamer with internal hard drive. In his case thus a router isn't even in his audio chain, and he still was able to notice a performance spike upon swapping its PSU. So there's something there.
Apr 26, 2021 at 5:27 PM Post #426 of 2,189
So his streamer uses wifi and not wired connection?
And when is ifi going to make bang for the buck Ethernet audio products like maybe filters or switch with your noice cancelation technique?
Apr 26, 2021 at 5:45 PM Post #427 of 2,189
His router goes wired to his streamer, but serves 'only' the purpose of control over it via wifi (a dedicated app on his smarthpone). Many people would argue that in this scenario a router only to control that streamer is way aside the audio chain, so as such it shouldn't affect audio quality in any way possible, but it does. A PSU swap for that router improved sound.
Apr 27, 2021 at 4:30 PM Post #428 of 2,189
I would consider that wired connection though. But he dont seem to stream music over internet you said he listens from hard drive?
After my experience with better psu=better sound for my router and switch with wired connection i would consider them in the chain. The noiser power\frequencies travels through the wired connection to streamer.
Apr 28, 2021 at 4:45 PM Post #429 of 2,189
That's correct. His streamer has in-built SSD for that.
Routers seem to be the noisiest, so having a switch should net some audible benefits.
Aug 19, 2021 at 9:14 AM Post #430 of 2,189
I bought a audioquest cinnamon ethernet cable earlier this year on sale for about 50 euros. I listened carefully before switching to the cinnamon ethernet cable. After switching to the cinnamon cable i heard a bit bitter separation, more air, and maybe a lower noisefloor. I have also tried a Transparent ethernet cable (about 350 euros) afterwards and it also gave an improvement to my stereo. It gave a better sense of space in live recordings. So yes up to a point i think its worth but it all depends on your current rig.
Aug 19, 2021 at 4:33 PM Post #431 of 2,189
Your observations are pretty much in line with observations of many other forum users who had some experiments with Ethernet cables.
Aug 21, 2021 at 7:44 AM Post #432 of 2,189
Hi all, just wanting to check is shorter better for ethernet cable? I think I should be able to make 0.75m work, but I read somewhere minimum of 1 meter for ethernet cable is ideal? Anyone here has experience to back this up? Thanks.
Aug 21, 2021 at 8:29 AM Post #433 of 2,189
Length doesn’t really effect audio performance in Ethernet cables, or at least it’s marginal especially if you’re looking anything 10m or less. After that, in hyper resolving systems you may here a very slight degradation over longer lengths :)
Aug 21, 2021 at 11:26 AM Post #434 of 2,189
This is not accurate. Packetized data either arrives and passes error check or it doesn’t. It’s literally impossible for there to be “slight degradation”, no matter how resolving a system is. If data isn‘t arriving properly, there would be dropouts, not some EQ like alteration of the audio during playback.
If that wasn’t the case, digital communication via Ethernet simply wouldn’t work. Ethernet doesn’t “know” what’s in a packet, so audio is no different than any other packetized data.
  • Back
