I was about to buy it last year.
I had been looking for something to replace or equal the Euforia for a long time.
When Matt introduced the Ultimate a year ago it ended up being what I was looking for, although I had others in mind.
I think the Icon is not bad as an amplifier.
There are a few things to know:
Personally, I don't like the different impedances because it limits the headphones or makes them seem bloated if you plug in low impedance headphones, for example.
Secondly, again personally, the 6SN7 story: Nos in particular have risen in price, especially since Corona.
A good pair is simply expensive and not necessarily economical as a user.even worse if you fall into the can hole.but there are still cheap ones so it's not like that.
3rd, the amplifier actually drives 300ohm headphones and others excellently, but in the end it is limited, especially for planar headphones, the He1000 should already be the end.
4th As far as I know, the amplifier can only drive 6SN7 and 12ax/AT7 Au7 should also work, but it is already getting darker in this direction.
There are 2 versions, the Signature is supposed to be equipped with Mundorf Sgo, the normal one with other caps.
Actually, it is a very good entry-level amplifier where nothing burns.
But for advanced players like us, who are perhaps still spoilt and like to roll tubes of different types, I don't think it meets the requirements.
In fact, we could have used more of Matt's 6AS7G amplifier, which is currently in prototype form.
@UntilThen by the way how much is the amp supposed to cost?
I would definitely recommend the Icon for newbies or those who want to try something different and keep things small, but not to people like us.
After more than 9 months of ownership, Ultimate is what I wanted and what fulfils me.
Every time I switch on the amplifier, I can actually switch my head off.
Some of us have gone through a long dry spell with Oblivon, Euforia and many more as amplifiers to realise this.
I am also sure that if I gave Eric 1000 us$ to build me an amplifier, he would build me something that is good and economical.
He has a wealth of experience to know what works and what doesn't.
I think he would build you the better Icon Audio Hp8,
