Deleeh
Why 0,68 uf for the Mundorf and 0,47 uf for the Milfex?
Why the 0,68 are better then the 0,47? I can‘t understand.Because Mundorf 0,47 uf is out of stock so Eric is giving us lucky folks the more expensive 0,68 uf and he says it’s better.
That is an UntilThen lure…. ….It'sNowOrThen sounds good. Eric sends me a picture of the coupling caps to be used in my Blackie Ultimate. Note the 0.68 uf Mundorf.
When I saw this, I ain't going fishing or golfing anymore....
It gives a response about it?
When your UltimatE comes home and you don‘t say too your Wife,
is a price diverses for sure but only the same reaction,.
… $1 / year for a million years or $1 / year for a hundred thousand years … … ?Come on Greg. Can't you see that 0.68 is bigger than 0.47? Logic will tell you a bigger number is better.
If I give you one million dollars or $100,000, which will you take?
I hope it’s going to be double boxed which is the standard for sensative items ‘ equipment.It's packed ! So well packed you can't see the amp. This is the best packing ever.
That is one transparent amp!It's packed ! So well packed you can't see the amp. This is the best packing ever.
