You're writing in great details now Deleeh and that's great !
I'm glad you're really on board even before getting the amp.
As I told you and Eric, I will take a picture of the silver and black wooden Ultimate when it arrives and it will be a great picture.
Somehow my friends didn't talk about the differences between the silver and wooden Ultimates. Even after one day, the wooden Ultimate is pulling ahead according to my ears. There was a comment which Simon made and I agree with it. He said he felt that the wooden Ultimate sounded more effortless and smoother but still dynamic and with slam. That about sum up the differences I heard so far.
Thank you.
Much of it is also a result of what I have read about capacitors and a bit of my own experience (especially the serious difference in the Euforia mod).
The capacitor alone is usually not the only difference.
This was also mentioned somewhere before.
There are capacitors that are good but do not harmonise in the system, but this is due to other things such as circuitry and components.
Sometimes even more needs to be replaced like resistors, op amps and so on. The SS range is even more sensitive, especially the modern ones.
Tube circuits are probably a bit more open and forgiving in that respect.
And to be honest it depends a bit on what your personal need is and the hardest thing is to find the capacitor that hits the mark.
Soldering is not difficult in comparison, and time is also an important factor.
The amplifiers take time to get used to and so does the ear.
With the Vcap, quite a lot happened in the first 400 hours and a bit more when that time was exceeded.
Simon's statement that the wood could be a little better.
It is possible that some signal paths are longer or shorter in the wood than on the aluminium chassis.
But this is also slightly more on the voodoo side.
But conceivable.
Personally, I can imagine that the Silk transformer could possibly give the extra power.
Maybe you will hear a difference when Eric is done with mine.
