sid311
- Sep 28, 2005
So I recently purchased these ancient gems about a month ago and have been in detail heaven ever since. However, as others have noted they are a little thin on the bass side. It is definitely there, just not at the same volume level of the other frequencies. I have a lot of experience with IEMs so I am aware of how to obtain a proper seal to get the lower frequencies to resonate. I use the foamies that came with them which seems to help out the bass a bit. I recently ordered a NuForce Icon Mobile and a P->S converter cable in hopes of improving the bass a some. Do any of you have any other ideas? As I see it my options are as follows:
-upgrade cable to APureSound-I have heard this helps some, but is very expensive.
-have custom ear molds made-read on the forums somewhere that this increased the bass a bunch but the etys still retained their clarity and detail.
-upgrade to a LOD cable from iPhone 3G to amp-I've read that the signal coming from the iPhone's connector port is much cleaner than the headphone out.
Any comments are greatly appreciated!
-sid
-sid
