ctm
- Oct 12, 2004
For all you technical gurus out there... please explain how you go about doing this.
Unfortunately, when AB'ing cans, it is difficult to equalize sound levels the way you can in a speaker setting (using the trusty Radio Shack or other sound pressure tester module). It's been well documented in carefully conducted listening tests with calibrated equipment, that as little as 1dB difference between one scenario and another (with everything else being equal) is enough to skew the preference to the situation where music is played at the louder level.
I will sit back and enjoy your detailed and thoughtful responses. Happy listening and best regards!
