Originally Posted by sumone
Saint.Panda, I'm gonna have to keep rereading your post, good stuff in there for me to learn. So the head transfer function...does this affect the full hearing spectrum or just midrange & up?
The HRTF is a rather complex thing and includes issues like sound resonance and diffraction, interaural time and intensity differences and other funny things. Also, even though it is called
head related transfer function, the torso and shoulders also add their spectral influences.
Regarding spectral influences, which contributes the non-flat graph, the basics is that whatever body part affects the sound has to have dimensions as to stand in a relation to the wavelength. Longer wavelength are lower frequencies. Therefore bigger body parts like torso, shoulders and the head itself affect lower frequencies whereas the parts of the ear affect the higher frequencies. And since in headphone listening the torso, shoulders, head don't play a role, the really relevant parts of the HRTF for headphone listening are only the frequency above 1-2 KHz. That's why headphone listening is fairly un-subjective under 1-2 Khz (assuming you get a good seal if we're talking about closed headphones).
I know for a fact that the probably 6-8khz needs to be left alone since if you go by the headroom graph (for the hd-280s), there's a 15dB drop. |
If you want to work with the Headroom graphs, also look at other graphs and see whether one headphone at one point in the graph makes a big jump. If that's the case, then it's most likely something undesirable.
One interesting thing to know about grahps is that shallow bump or dip is more audible than sharp spikes in the frequency response, because a irregularity small in deviation but large in frequency band crosses several critical bands in hearing. Note that this is completely opposite to what most people believe.
I also find it hard for me to pinpoint characteristics such as transient response, soundstage, imaging, etc. My whole world of "headphone audio" thus far has just been how good the frequency response is. Either my ears aren't quick enough or I just don't know how to discern these properties. |
Your ears are definitely quick enough. Soundstage is probably rather easy to detect and the rest comes with time and more reading and experience for sure.
Still, which line of the headroom graph do you read? Is blue left channel & red the right channel? |
Not sure what you mean but left and right should be rather similar if its a pink/white noise. Left and right ears are never 100% identical which is why there are small differences in the graph.
For a bit more info on this (and in better English
), you can read a bit more in this:
http://www6.head-fi.org/forums/showthread.php?t=130998. Open the pdf and go to chapters 4.1 and a bit of 4.2 and the 'further reading' links at the end of the pdf file.
