gregorio
- Feb 14, 2008
I would start with flat, not a slope, although most likely a relative bass raise will be required. There are a lot of variables going on.i also think the best way to get a universal EQ right is to use a linear slope (which are suggested often if you search for "house curves")
But it’s not a filter, exciters add synthesised harmonics (and usually phase distortions), which raises the output level.Any kind of filter might push a hot mastered track over the edge.
Yes, as explained, the whole point of an exciter is to change the tonality. However, whether it adds a “metallic sheen” depends on what you’re inputting into the exciter. If you’re inputting a signal from say an old tape, which is missing mids/highs, then an exciter just adds back some brightness and/or “air”, but if you feed it something that already has a lot of mids/high then it will most likely just make it more harsh/metallic.but it(exciter) throws the tonality of the track off to add this extra metallic sheen to the track.
It’s similar but not quite the same. Exciters usually add freq dependant phase and also allow a user defined balance between added even and odd harmonics.a exciter adds just harmonics, which basicly is the exact thing as increasing distortion/THD
Why not?of course music wouldn't sound worse if it sounded better to you.
Spoken by someone who knows little/nothing at all about audio processing, how/why it’s applied. At least you’re consistent, as ignorance is virtually always the basis for your BS answers!that's literally the whole point of audio processing, to make things sound better.
And yet when asked for an example of where I am wrong (according to the facts/science) your only response is insults barely worthy of a 5 year old. Therefore, the only “rule” you are consistently demonstrating is that you must be a troll! Let’s see if you can demonstrate that yet again.and of course sound science rule#1: gregorio is usually wrong.
G
