The solution would be to normalize the track down 2 dB and then apply the filter and see if it works.
yep, if you dont wanna "try" to find a solution do it this way: if you boost a frequency by 5.5db then set a "preamp" before the eq to -5.6db, always consider 0db volume going in, then you wont have a problem with clipping
another solution i used before is also this: instead of using a lowshelffilter to boost bass you can actually use a highshelf filter to reduce everything but the bass, then you dont need to preamp
I just want to get as close to what the master sounds like without mucking up anything on my end. I guess EQ can run counter to that, but I posted this here because I know sound science will bias toward fidelity and reproducible knowledge pertaining to the topic.
yes for reproduction this should be always the goal and flat speakers (+ some house curve) dont need an exciter, the only things i found useful so far for reproduction are:
1. EQ - whatever EQ, Graphic, Parametric, Convolver etc tho i like Parametric for the ease of use and being precise and having options like high/low shelf/pass
2. Compressor - if you dont want high dynamic range (at night for example)
3. Crossfeed - for headphones sounding more like speakers
4. Limiter - not "really needed" but nice to have and easyeffects on linux allows with the Limiter Plugin to apply Dither
5. (maybe) Deesser - tho its not really needed with the right EQ
6. (maybe) Pitchshifter - 99,9% will not use this but i do, to retune 440hz music to 432hz
but it(exciter) throws the tonality of the track off to add this extra metallic sheen to the track.
this is kinda the point of the exciter plugins, to add more high frequencys to make it "excite" you, but its far from good (neutral) reproduction
tho if you want you can play with it, maybe you just overdone it and actually like a mild exciter,
i also found out that im quite sensitive to effects/eq, i can kinda tell if a EQ for bass/high frequencys is off by 0,2db to 0,5db (A/B i also hear a difference on 0,1db but in the longrun this doesnt matter much)
also pitchshifter plugins are not perfect they seem to tend to mess with the phase/volume a bit
i also hear differences between different EQ software, the best i found so far is EasyEffects on linux with inside the eq plugin "mode: SPM" set and for every filter "Mode: APO (DR)" (well i didnt heared a difference before but with trying the different modes (and A/B them) in easyeffects there is certainly room for good or bad implemenation)
