Oya?
- Mar 31, 2008
Hi guys, I'm trying to case up an amp and power supply in a modest ABS enclosure. This is really technically only my 2nd DIY build so I'm not really sure if I'm laying it out 'right'.
I was thinking of just doing a really simple layout like this:
But there's kind of a lot of wasted space in this pic, and I'm thinking I want to stick a toroid (salvaged from my broken Millet!) in there as well so that it looks like this:
What I really have no clue about is how much distance I should keep between the toroid and AC wires, and the amp, pot and signal wires etc.; In this pic I've moved the toroid as far away from the amp as I could but even with careful wiring I don't know if there's enough of a gap. I'm also not really sure where to put the regulator. Does this look acceptable, or will I end up with a noisy amp?
I also bought an aluminium sheet which I intended to use to mount the toroid and also ground the IEC earth to. If I cut it up, and used a piece as a shield like in the red line I drew, will it do anything to help make it quieter?
Any help would be appreciated!
Thanks.
