allhifi
- Jan 16, 2017
The Hifi man headphones are unusual because they are designed to use HUGE amounts of power when producing sound. We are talking 6 watts (6000 miliwatts!) @ 35 ohms from the specs of your headphones. So, this is the amp to easily deliver this power. Very few amps come anywhere close to its power output. Do some googling and you'll see what I mean by the kind of power your headphones need.
Luckily this Basx amp is one of the very few that can and pretty much the only one near the price it sells at.
It can put out 12 watts (12000 miliwatts) at 35 ohms. However make sure to bypass the resistors when you get it. If you don't, it is purposely limited to 0.2 watts or 200 milliwatts at 35 ohms by the resistors (not enough). So for your Hifiman, bypass the resistors. Don't worry, you are supposed to and this is a feature of the amp. The instructions on how to do it are in the manual and requires no special tools.
Thanks Grim: With that said, I'm confident the A-100's SQ is commensurate with its prodigious power output (into can's) ?
pj
