I’m hoping some Basx A100 owners or reps can help guide me with a problem I’m having. It’s a unique case.. I’m using the A100 to power my Jecklin PS2 Electrostatic Energizer (the equivalent of a Stax SRD-7). I’d previously used a little Kinter Tripath amp that worked well, but upgraded to the A100. When connected to the PS2 I get audio but whenever I turn the volume up loud (about 12 o clock, which doesn’t really have much volume, I’d say just loud but listening levels), it goes into blinking-amber fault mode. Originally I was using bare ended speaker wire so thought it could be a short in the speaker cables, as per the manual. So I swapped over to brand new banana terminated cables and still have the issue.
I’ve checked the A100 and PS2 fuses and they’re all good. The 4.4 terminal jack produces good sound at loud volumes, so I think it’s entirely to do with how the A100 plays with the electrostatic energizer (about 800-900 cola, if I recall correctly, not 580 like Stax).
Two main questions:
1. If not a speaker cable short, any other ideas what may be kicking it into fault mode? At higher volume only?
2. Could using the jumpers help in any way, by giving the amp more power to handle the energizer?
Any other thoughts are appreciated, and there’s no Jecklin thread I can post this to, so you’re my best hope. My fear is that a cap is blown somewhere in the chain, but if so, I’m not sure why would it work at low volumes but fault at high.
