RnB180
Member of the Trade: RnB Audio
- Jul 2, 2004
Before you jump the gun, I think you should wait a bit more for responses from other members. I didnt read the whole thread through but skimmed through it. BHD seems to have some very informative insight.
If I were in your shoes Id take advantage of the return policy, toss all preconceptions out the window and listen for myself and assess the amplifiers personally.
A persons opinion does not necessary reflect what you may percieve as enjoyable. Ive been lucky enough to meet both manufacturers at the so cal meet in person and test the gears they had on display.
I am however not in the correct position to offer a fair assessment since I did not spend much time with either amplifiers, If I were to do so,, it would be unfair to the manufacturers and may possibly give an incorrect recommendation on my part.
I think the main differences between both amp builders are that their line exhibit a certain signature trademark.
You are best to call up both ray an justin for their opinions on their amplifiers.
If it helps any I think Ray tunes his amps with the sennheiser hd600's and akg 701's. So I do not believe synergy would pose a problem with either can.
I did not listen to the GS-X for very long, but did notice the 600s sounded very nice with the GS-X also.
sorry I was not much help, you really are comparing two very solid amplifiers and the higher up the chain you go, the more difficult these decisions become.
Good luck.
Originally Posted by mazersteven The Headamp products, the Gilmore Lite w/ Dedicated Power Supply. Or a GS-1 would suit my needs, and pair well with my Senn 600 & AKG 701's. Just out of Curiosity. Is there any other Amps, someone can think of that would be a better choice? |
Good luck.
