lucidreamer
- Apr 2, 2015
Glad to hear that the seller is allowing the return and making things right. If the test ratings for the set were just "okay" on his tester, he should have never labeled the listing as NIB... crazy.
As far as the readings on his tester for power tubes, almost all of the vintage testers have issues with weak transformers and thus, may read certain power tubes with more inaccuracy than others. Over time, not only use, but even by just sitting on a shelf, the transformers will eventually start to weaken. Unfortunately there are very few, if really any, options for new transformers, since they are unique to these testers and have to be hand-wound, etc. In general, vintage testers with weak transformers will have issues with the higher output power tubes, such as KT88s and 6550s; EL34s are generally less taxing on the transformer and thus will often provide more accurate results though. A gas/leakage and short test shouldn't be affected by the power of the transformer though and the Hickok "Life" test can also indicate if a tube is near the end; I've had tubes with great emissions results, etc., but with an extremely poor life test, so it can be useful.
Let us know how the repair goes and if you ever find out from the seller if one of the tubes now tests bad; it's also smart to have a few extra FETs, just in case this happens again. It would be helpful if all of us were able to get a better idea of what will/can happen when a tube fails in the Elekit though, if this is what happened to cause the FET to blow. Eventually, even with the newer production batches, and sometimes even more often with them than vintage, all tubes will fail, so it will happen at some point. I find it interesting that unlike my other experiences with tube amplifiers, the Elekit seems to have issues with dying tubes, beyond just the tubes, however I'm still wondering what the ultimate verdict may be, as the structure did not collapse/spark when the LED turned and the sound cut out. Thus, it would be interesting to find out if it was just something wrong with one of the tubes or that their life had finally been used up.
I hope you're up and running again soon!
Thanks Effusion! I actually got the spare FETs from Amazon last Saturday and fixed my amp already by replacing both Q3 and Q4 with NDF02N60ZG FETs. It sounds the same as before (knock on wood) with my other NOS Westingate EL34 single getter tubes that I got from eBay. These are really new set of EL34 XF2 tubes that I bought for a fair price on eBay. I think from now on I will try to stay away from used tubes and sellers who have no return policy, just too much headache and risk to use your amplifier as a tube tester. I cannot hear any sound differences between EL34 double-getter and single-getter tubes, but the latter costs 1/3 less which are also easier to find NOS! I think it is a really a great deal as long as it lasts.
It would be great to have some additional "bad tube" electronic protection implemented in the amplifier design to prevent blowing FETs and other parts, something like small replaceable fuses or cut-off relays, etc. I have no clue what could cause the XF1 tube go bad, as mentioned before, both tubes sounded just fine for about a minute or less, then one channel died quickly and I had a red light come up. Probably over the age, some pins or leads internally started shorting out as soon as the tube heated caused by tiny expansion in the metal structure due to heat. The tube was still glowing up normally as before, no pops or sparks were visible. Depending on what specific pin may be shorting I believe that this guy's tester may still be reading this tube as good, since the tube did not explode or died completely. That is why it is really wise for professional tube sellers to invest into really good modern tube testing equipment. Based on his irate responses, plain lies and contradictory arguments there will be no surprise to see these tubes popping up for sale again in the near future only making eBay an even worse place for audiophiles. Caveat Emptor!
