JK-47
- Jan 2, 2015
Thanks for the info Victor, but the TU-8500 capacitance is still a mystery....
hi JK-47
If you look at Audio Research Reference Phono 10 or other expensive phono amps, they won't tell you the capacitance too.
I trust Mr Fujita's design.
I will try one more time to ask him to let us know the capacitance .
I don't doubt Mr. Fujita's designs, his Amps are awesome
I just wanted to be able to match my turntable cartridge, or future upgrades to the recomended values. My previous Schiit Mani had a capacitance of 100pF, and even with the wiring was borderline on the low end of the 150-300pF recommendation. More for piece of mind than anything else.
I will definitely be adding another Elekit amp in the future...300B.....
Welcome to the club lucidreamer!!!!
Great mod on the volume knoblooks sweet.
I saw a the same mod on a different Elekit amp on another forum, and it's nice to see it implemented on our amp.
Keep us updated on the tube rolling
I am just curious if it is normal that the whole metal chassis case getting pretty warm after a short while when the amp is running? I mean it is not too hot to the touch but is pretty warm let alone the tubes which are actually hot. I believe it should be normal, since the tubes emanate heat that is dissipated and evenly distributed by the metal case but I just wanted to double-check.
When I first assembled the amp, I let it run for a few mins only to make sure there was nothing wrong with it, like excessive heat, smoke, etc. or the transformer making noises. Then I put the case on. I should have probably tested it for a hour at least without the case to make sure no parts get overheated or something (except the tubes, understandingly). In my experience, if something is not done right, it may still work ok, but some components may be overheated and burn out quickly.
Thanks.
The power cord that comes with the Elekit is a two-prong plug with floated ground wire that looks identical to the one for theTriode TRK-3488. I learnt my lesson last time where floating ground silenced hum. It took me no time to reconfirm that on the Elekit. I compliantly replaced the more expensive three-prong power cord with the humble-looking stock.
In the TU-8200DX manual it is recommended to attach the ground wire to the electric outlet if it does have a ground terminal on it. But here in the US all the 120v household outlets already have 3 prongs anyways. Why not replacing the stock one with the 3-prong cord then. Did anyone notice any issues after trying the 3-prong power cord by chance?
