- Oct 14, 2013
I am planning with Lundahl dual transformers now LL1690. It doesn’t seem that it needs any resistors. The line in should be already with some kind of gains as the 8900 has the preamp tubes. So the transformers go right up to the input stages of RCA is alright. It is better than just going straight Balanced to SEIf you want to have balanced input you'd need a pair of small transformers. Cinemag and Jensen both make them. I believe you also need to integrate a pair of resistors; you can check with them about the value.
However, I need to see the schematic to judge further. Jensen recommend 2.4K resistors for between the output of RCA. Lundahl recommend a couple resistors and a cap
