- Sep 7, 2002
For those not in the know, the Eichmann bullet is an RCA connector which gets rid of the outer ground connector for a single small contact point. The rest of what would be the outer ground is just some form of plastic.
http://209.85.173.104/search?q=cache...lnk&cd=2&gl=us
I got my first set of these with a pair of used silver cables. I had no idea how much of the quality I heard was the bullets versus the cable but I got few more bullet-terminated cables and have liked them all a great deal.
The theory of them has something to do with eliminating eddy currents in the ground. Again no idea if this is the true story or not but it did occur to me that when inserted in many RCA sockets you may not be getting the full benefit of this approach because the small contact (which looks like a small ball bearing) not only presses on the outer part of the socket (as it should), but also sticks out slightly ahead and therefore can in most of my set-ups make contact twice, in 2 spots 90 degrees apart. In some cases the contact is even grounding on the case of the component.
This could even happen with some conventional RCA plugs.
So I thought, there's a simple solution, just pull the bullet plug back a millimeter or so such that it no longer contacts anything in front, just makes contact with the ground on the socket.
And it seems to make the sound better, cleaner, more distinct.
BTW if you have these plugs and don't hear anything different feel free to say so. But if you don't even have these plugs, don't waste everyone's time with your uninformed claims that it can't possibly make a difference.
