Originally Posted by UTF /img/forum/go_quote.gif
What you and parra said here make me wonder if I made a wise purchase of EF1 for using with HD600 (my EF1 is still on its way to me).
Is what its missing to sound right there related to its power, synergy, or something else? Would tube rolling help? Just cannot wait to try HD600 on it.
It is in not bad, by any meanes, but the DV 336se is just better with the HD600. In my ears at least.
Originally Posted by KevM2 /img/forum/go_quote.gif
That is definitely interesting to note. What would you say is the difference in sound? What makes the DV336 better than the EF1?
To me it seems like the EF-1 delivers a good amount of power, but its missing just a bit to put the sound 'right there.' I've heard that the DV336 did have more synergy, but I'm wondering what sound qualities it delivers that makes it superior with the HD600s
My EF-1 is stock, using RCA clear top tubes, stock op-amp.
I would describe the sound from the AF-1 compaired o the 336se:
- The 336se has more open sound, it is like moving closer to the stage
- 336se has better instument separation (big difference in my opinion)
- better soundstage, but here the difference is small. I dont think the HD600 is capable of delivering a big soundstage, not with the EF-1 or the 336.
- The EF-1 is flater and more dull, compaired to the 336
-It is like the 336 is just a bit better dance partner then the EF-1, and makes the HD600 swing even more/better.
Going from the EF-1 to the 336 is a bit like watching a picture througt a glass, and then remove the glass. the difference is not huge, but I enjoy the 336se more.
Even if the 336 delivers better sound reproduction then the EF-1, it seems that the HD600 have more to give, and a WA6 is probably gonne be very good.
high ohm HP ---> 336
Low ohm HP ---> EF-1
Stian
