The sound the EF1 gives off is a thick, somewhat heavy sound when I listen with the HD600s. Overall, the amp sounds quite good, but I'm a bit of a perfectionist and I'm constantly looking for improvements. I'll proceed to try and describe exactly what it is what I'm looking for.
It might have more to do with the sound signature of the HD600s when they aren't getting all the power they need, but what I especially need is a more intensive 'tone'. Certain instruments play thick, but sound soft, such as the horns in certain songs. I need a little more blare.
I just need a sound that is a bit more engaging. With the HD600s, I'm no longer hearing 'the veil' after some of the adjustments I've made (Equinox cable, interconnect adjustment, etc.) but the sound is somewhat condensed, and polite. I guess it can have a slight syrupy feel to it.
I'd like the sound to 'spread out' a little bit. That heavy, thick sound can feel real weighty on my head, which causes me to take the headphones off every now and then. It has somewhat of a 'stuffy' feel to it, sort of like going outside on a humid day. I want a big, powerful, slightly faster sound without all the thickness... I want less politeness and more immersion, but without having the sound get brighter.
In essence I want to feel I'm closer to the stage... The Senns have often been said that they are headphones that are better to listen to at higher volumes on some amps. So I'll use that to describe what I'm talking about. To see where I'm coming from, listen to the 600s at a low volume and observe the sound. Then move the knob on the amp to a higher volume. At low volumes, the sound doesn't simply lower and yet retain all of its traits it had at a higher volume. Everything starts to sound more distant, softer, like details start disappearing into the air. In other words, recessed. When you turn the volume knob up, the sound doesn't merely get louder. The sound starts filling up and becomes more engaging.
I'm currently past the 'veil' stage with my set-up, but what I'm trying to do is get rid of the politeness without turning my system into something bright and annoying. I want a bolder, more dynamic, clearer, powerful sound. I was just wondering if the WA6 takes 'more control' of the headphones and makes them sound more dynamic. I've heard the Zana Deux really takes control of the HD600s, but that's twice the cost of a WA6SE.
