Eek... I was a cable believer, until...
post-779807
Post #16 of 137
radrd
Found that torchiere lamps induce nicotine addiction in moths.
Welcome to my world.
I did the exact same test you did with some cables that were supposed to sound very different from one another (Nites/$100 silvers) and they sounded exactly the same. I tried fast switching and I tried slow switching. It didn't matter, there was no difference. I now don't believe that expensive interconnects hold any value for me. Maybe someone with golden ears can hear the difference, but not this sucker.
Two different people told me I should upgrade my gear in order to hear the difference.
post-779853
Post #17 of 137
Edwood
1/2 hamster, 1/2 Turkish∙ Blueteething
Cage
Cage
Originally Posted by lan
Do you have power conditioning? I find it's easier to detect differences when you have clean power.
I also don't like swapping back and forth real fast. I think the ear needs a small reset time to readjust.
Why don't you try these cables on another system?
Yes, power helps and hurts.
I don't agree with letting your ears rest. By then you have to rely on your short term memory, and then it's more perception by then. It does help to do both. But if I had to pick one, I'd go for the rapid switch method.
-Ed
post-779880
Post #18 of 137
greenhorn
Originally Posted by bangraman
...you cannot imagine how depressed I am at the moment. I easily have $2,500 invested in interconnects and... well, this is bad news.
Hey, bangraman... if this helps... I am ready to replace you all that stuff with... (...drums...) *brand* (yeah!) *new* (wow!) *stock* (cool!) *cables* - for free!!!
I'll even go the extra mile and pay for both my and your shipping costs.
'coz I'm a nice guy.
post-779971
Post #19 of 137
Ctn
I think Rapid switching is the best method.
The brain is good at noticing instant changes. The brain has very bad fuzzy memory.
Finally a few people actually have the same findings as me *SHOCK HORROR*
http://www5.head-fi.org/forums/showthread.php?t=70105
I do have very clean power from what I can tell.
I disagree here. I think if you let the ears/brain adjust, you'll memory of what the sound is goes all fuzzy/blured. The longer you listen to the current cable, the more your memory of the previous cable goes all fuzzy and the more likely you will "hear" the difference. Assuming our brain acts like a nn.
Rapid switching (say 5secs each) keeps both memory relatively "current".
Me too. I'm thinking my gear is way better than yours buddy.
post-780012
Post #20 of 137
ampgalore
The only way to scientifically test this is by performing a double blind test. However, since this method of testing is not allowed here, rapid switching will have to do.
I am actually quite glad to hear that there is no detectable sonic difference between good quality cables and more exorbitantly priced ones. As this further strengthed my conviction that I will never spend a couple hundred dollars on cables.
post-780016
Post #21 of 137
ampgalore
And come to think of it, electrons are electrons, conductors are conductors, once you reach a certain point of good quality, what else can you possibly gain? They are basic conductors after all.
post-780042
Post #22 of 137
lan
Videographus Supremus:Makes audio cables using super-advanced materials, like "some clear tape" and "some not so clear tape."
I guess our methodology and reliance on memory works different. I don't need to swap back and forth between pizzas (or sex partners
) to determine which one was better. Hearing is just another experience and the cable which is better to my ears will sound more natural. Swapping back and forth too fast is unnatural experience. You can't get used to any of the gear.
post-780047
Post #23 of 137
fewtch
You could always get used to the gear first, then perform the tests later.
post-780055
Post #24 of 137
Ctn
It's how we detect changes. It's like trying to detech small changes in the different tiff pictures. It's very hard to look at a pic for 10mins then switch pics then find the changes and repeat. It's easier to detect the changes if you rapidly switch. The changes will emerge out of how our brain work.
I guess our methods are different.
You dont let someone inflict 10 mins of pain on you before you go ouch ? hehe jk.
post-780074
Post #25 of 137
Ctn
Eep cant resist....bad ctn !
You'll probably wont live long if you did rapid switching test for sex partners :>
post-780078
Post #26 of 137
gpalmer
We are the weird ones.
Although I've seen movies like that...
post-780088
Post #27 of 137
Ctn
I cant believe you said that, Im in stiches atm.
post-780849
Post #28 of 137
Calanctus
If you look at how professional audio reviewers (yes, there are a few really good ones, among all the chaff) review gear, you will notice that they typically spend days or weeks with a component before making a judgement as to whether they really like the sound.
Why would they do this, I wondered? Then I tried the process with 2 different preamps, one tube and one solid state. The quickest I could do the switching was about 5 minutes, and the results were very inconclusive. I just couldn't really decide which one I liked better.
So I left the tube preamp in my system for weeks, listened to a lot of stuff, and eventually switched back to the SS preamp. Result: NOW I could immediately hear a difference. (The tube gear is up for sale; I'm keeping the SS preamp).
I'm not sure exactly what neurological or psychological process is at work here, but I know what I heard. You can say "You should hear this, you should hear that", etc. etc. all you want, but the facts are that prolonged auditioning showed differences that quick switching failed to do.
yes, all the other disclaimers apply as well: You have to have a good enough system to show differences, good power, good recordings that you are very familiar with, etc., but time does make a difference.
This is not to say that I CANNOT hear differences with quick switching--sometimes I can--but the results are far more satisfying to me with a prolonged audition.
post-780890
Post #29 of 137
lan
What I'm saying is that you can't switch too fast since your ear/brain needs some time to readjust to the swap. That getting used to is like spending a few minutes with each cable before swapping. It doesn't really matter if you spent a few hours before hand getting to know the equipment. Any comparision gets lost in that inital transition period.
I don't consider sight the same as some of the other senses because taste, touch, and hearing can be related to pleasurable experiences. For comparing pics, going back and forth quickly is the preferred method. For things that are experiences, which are more analagous to taste, touch, and hearing, switching too fast doesn't work in my view.
Take bike riding. The transition period is like mounting the bike. There's no way you can make a good comparision just in that time frame. You have to ride the bike around for a little.
Take beer comparision. Going back and forth between 2 beers will ruin the taste of each. You won't be able to appreciate each in its entirety.
post-780957
Post #30 of 137
PinkFloyd
You gain the placebo effect from looking at the funky, uber expensive cable you've just bought and Kudos from other head-fiers when you tell them how much it cost.. that can go a long way to make something sound good and there's nothing wrong with that.
