SirAuron701
Hello everyone, been reading parts of this forum for some time now and having saved up a tidy sum I wanted some help with deciding on a new set of headphones and to learn a bit on amplifiers.
I was initially looking into headphones in the up to 200 euros range and the main contenders I have found are the AKG 701 and the Beyerdynamic DT-990. Other models I have come across are either not available in Greece or far too expensive here in Greece (e.g.HiFiman, Grados etc.)
I am mainly listening to jazz (free, avant-garde), various instrumental (20th century classical, downtown music, soundtracks etc.) and some experimental/electronic music (IDM, experimental rock, etc.). However, I do have a somewhat wider palate and do dive into other styles from time to time so I would like a set with no distinct drawbacks. As you can imagine crispy clean tremble and a wide soundstage are essential and I do like to listen to the music as the engineer intented it (i.e. not massively altered by a boosted bass for example) so I feel that what I have read on the AKG 701/2 make them a good choice for me. However, I would love to listen to what people can suggest for me, even if it is outside of my price range. I would rather wait a bit and get something better, so long as we are not hitting massive diminishing returns in regards to value for money.
The real reason I am here is that by reading through the forums, especially a very illuminating post on impedance and sensitivity, it seems that an amplifier is all buy essential for most headphones in this price range (and above) which means the cost will skyrocket from about 150 euros to 300 for a solid amp. Therefore, I have the following questions
I) Are there headphones on the sub 400 euros range that can work to their full capacity without an amp? I am of course referring to audiophile cans that would produce a sound equivalent to their pricing. If that is not possible would perhaps a sound card paired with low impedance/high sensitivity set do the trick?
II) My motherboard is the following. Can it perhaps provide enough power for such headphones? Where can I find this information?
https://www.asrock.com/mb/amd/fatal1ty b450 gaming k4/index.asp
III) If an amp is essential how limiting is the choice of an amp in case you decide to try a different pair of headphones? I can see there are lengthy discussions on what amps go with each pair of headphones but I am not sure how adversely mismatching the amp and the headphones can affect the sound quality.
IV) I have read that an independent sound card is generally not needed unless you own top notch equipment. Is that true or should I also be looking for a standalone sound hard to come with the headphones? I will be using them almost exclusively with my computer.
I assume much of this has been answered in other parts of the forum but I was unable to locate those answers. I will be happy to read through if you could point me to the right direction.
P.S. Looking for open headphones as leaking is not an issue for me.
