what headphones have you tried with the BA.
Eddie Current Balancing Act
- Thread starter Varma
indiehop
- Mar 17, 2011
Right now I have the Sennheiser HD-25's, and Grado 60. I am waiting for a pair of Audeze
I am tempted to pick up a pair of HD650s. But one can only listen to one headphone at a time. But I guess one can connect many headphones considering there are so many outputs on the BA!
yanfeng
- Apr 18, 2005
Very interested in this amp. Would very much like to know its performance with HD800 compared with other amps such B52. Thanks!
just picked up a K701. another winner with BA. here is my in-depth review of the headphones i have used so far with the Balancing Act (300B tubes).
* 10/10 in sound: RS1, GS1000, R10, LCD2, K701
* 7/10: HD650, HD800
* 4/10: K340, K1000
want to try DX1000. think that will work well too. plus i really need to try some PX4 tubes.
* 4/10: K340, K1000
@indiehop - you need some more headphones!
KingStyles
- Mar 4, 2009
I would add the LA7000 - 10/10
1117
- Jul 15, 2006
I was away on vacation, and forgot the settings for the power supply.
For those with the 300b/px4 combination, what voltage is the meter on the power supply to be set to when using PX4 tubes? 4 or 5? I forget... sorry!
KingStyles
- Mar 4, 2009
The px4 uses the 4v setting.
rosgr63
Don't forget the switch at the back!
as mentioned, PX4 is 4 volts. 300B is 5. and you need to have the switch on the amp in the right position as well.
I wonder how the different negative grid voltage for PX4 and 300B bias point is adjusted, in case the rear switch only changes anode voltage and pin socket relation.
Does the negative grid regulation been automatized by the circuit itself? Anyone knows?
rosgr63
I don't think the rear switch changes the socket relation. I believe that the socket connections are the same for both PX4 and 300B.
As a matter of fact you could run some PX4's with the rear switch set for 300B, but please don't try it.
Craig told me I could with some of my modified PX4's.
KingStyles
- Mar 4, 2009
In the past a few of us were complaining about hum from the transformer in the power supply. I was one of them. If you have hum, you probably have something up with your power. I just added a aps purepower to my setup and I no longer have that hum from my BA power supply. Just a thought if anybody cared.
rosgr63
I care!
I am pleased you confirm that a clean power supply is top priority.
rosgr63
They sound great!
Anyone tried ultrasone editon10 on BA. How does it sound?
They sound great!
