Nirmalanow
- Jun 17, 2006
Originally Posted by Nirmalanow /img/forum/go_quote.gif There are some other limitations. This is not a portable contraption by any means, and it is awkward having more wires running to your head. Also to use it with a typical headphone rig, you have to run your headphone output through the Echofone. I was loath to take the output of my $1000 Yamamoto amplifier and run it through the electronics and volume control in the Echofone (note to manufacturer: maybe make an audiophile version with better power supply, more powerful amp, better connections and a loop through output at line level?), Fortunately, I use a Trends UD10 USB converter to connect my music server computer to my external Monica DAC, and the UD10 has a headphone/line-out output that I was not using. So I was able to hook up the Echofone there, leaving my headphones jacked directly into the Yamamoto. sound therapy, accelerated learning, hearing loss and attention deficit relief. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif Do you have pictures of a person wearing the bone conduction pads and regular headphones at the same time? |
Originally Posted by Nirmalanow /img/forum/go_quote.gif I have simplified my echofone system by using a Pico as a DAC/preamp feeding a y-splitter to both the echofone and my main headphone amp. In this way I can preset the relative balance of echofone and regular headphone volumes, and then use the volume control on the Pico to adjust the overall volume when a particular song comes on too loud or too soft. I do not have to adjust two volume controls (actually three with the output to my aura bass cushion), but can just use the Pico as a master volume control. I have tried different setups to see if I can get the same incredible presence and fullness of sound without the added trouble of using the echofone, but nothing equals the combined effect of the headphones, echofone and a very slight bass boost from the aura cushion. There is much less sense of listening to headphones and more of a sense of there being music happening in the room with the added inputs from the echofone and the aura cushion. I am getting a pair of Markl Modded D5000s. With all of the hype about these phones, it will be interesting to see how they compare on their own to my combination of phones, echofone and bass cushion. Will I still find I want to use the echofone in addition? |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I would guess that once you get addicted to the sound augmentation of the echofone + headphones + aura cushion, that it will be hard to go back to just headphones, no matter how good. When echophone is under $199 I might get one to try. |
