- Jan 30, 2011
@money4me247
I may be able to shed some light on what I use. As castleofargh said, it can be a nightmare if you're using headphones with highly contrasting frequency responses, but it's not too bad if you're trying to compare headphones with roughly similar responses.
I use constant test tones - 300 Hz, 1 kHz and 3 kHz. For most of my comparisons, I tend to use the 3 kHz one the most, as it's where the vocals are often most prominent, and my own listening tends to be striving to have vocals matched - then comparing other parts of frequency response in relation to vocals.
For an spl meter, I use an iPhone5S, and an spl app. It's only supposedly accurate to 1dB, and I have no way of calibrating it, or checking it, but I have noticed that it is very consistent in in its measurements. The main aim for me when doing this is simply to stop volume matching "by ear" as I know my own ears are not as accurate as the meter. And for reviewing - I clearly state that my reviews are purely subjective, but using the volume matching is my attempt to at least be more accurate in interpreting my own subjective observances.
If I'm doing full sized headphones, and the cup sizes are similar, I'll take some foam, shape it to the cups, cut a slit for the 5S, and then position the whole set-up so the 5S is as close as I can get to being consistently placed relative to the driver (I measure against 1 driver each time). This often involves aligning the S5 adjacent to a screw or mark on the yolk, so I can get consistency. It's really important to have the mics the same distance from the drivers - so you have to play with this to get it as close as you can.
Then I run the app, take the measurements, but more importantly, take multiple instances. As long as the measurements are showing consistency, I note the volume on the pot on my amp (or DAP - the X5's digital control can be very handy). Next I compare using actual music with the measurements I've taken (IE adjusting the pot to what I've worked out is a volume match @ 3 kHz). If they sound the same to me - I then repeat the tone test (measuring again) to make sure it's still consistent.
Once I'm fully satisfied - I then do my comparisons, and make my notes.
I full recognise that the system I use has a lot of room for inaccuracy - but it's as good as I can get it without spending hundreds of dollars. I also have a similar setup for IEMs.
Hope that helps. It was invaluable for me doing my DT880 and T1 comparison and is proving to be very helpful with the HD600 vs HD650 exercise I'm embarking on now.
Cheers
Paul
Cheers
Paul
