EarMen Sparrow
- Thread starter Miroslav EarMen
- Tags
- earmen earmen sparrow
onlinekute17
I suppose if Earmen don't get in touch with me in the next month or so about sending a replacement and the new ddhifi cable also still has the same rfi issues at least there's another cable I can try!
I think you're gonna be waiting for a while for a replacement cable mate.
Last time I spoke to them, they haven't got any ETA yet.
onlinekute17
Just found this cable on Amazon UK. It's 50cm and seems to be adequately shielded.
https://www.amazon.co.uk/SEBSON-USB...e+gold+plated+0.5m&qid=1611597980&sr=8-1&th=1
I won't be getting one since I'm selling my unit. But UK folks having issues with the Sparrow EMI noises may want to give it a try.
Any news regarding the replacement (shielded) usb-c cable from Earman?
Thanks.
Thanks.
AlonTZ
BannedMember of the Trade: HiFiConnectAKA Jacob ISR, ZigyS, FelixDJ
Got the Sparrow here too.
Amazing little device!
I replace the OTG cable with OEA OTG and all the problems are gone. yes it is not cheap cable but worth the price.
AlonTZ
Also would like to recommend using USB Audio Player APK (on Android) and enabling Bit-Perfect.
propolis12
Could you post a link here ? ThanksGot the Sparrow here too.
Miroslav EarMen
Member of the Trade: EarMen
Dear Valued Customers,
We would like to inform all of the Sparrow users who have an issue with a USB C cable to contact us in order to receive a new cable replacement.
You would need to send the order number or any proof of purchase, as well as information about receiving the shipment to the following mail: sales@earmen.com .
Thank you.
EarMen LLC
Thank you.
EarMen LLC
AlonTZ
https://www.oeaudio.net/oeotgCould you post a link here ? Thanks
My friend got the Iphone variant and it works well with the 11 model too.
AlonTZ
Remember to mark one of the connectors so you will know which side to phone and the other to the DAC/dongle - it is important to keep the same direction.Could you post a link here ? Thanks
Hey all,
Is anyone driving a Hifiman Sundara with their Sparrow?
Is there.enough power there? What it like on the single ended output?
Thanks guys!!
Thanks guys!!
From the Balanced output is more than sufficient for a portable device.
Single ended is not powerful enough.
AlonTZ
The BL output is much powerful and sounds way better than the SE - i suggest you replace your Sundara cable or the headphoneHey all,
Thanks guys!!
Miroslav EarMen
For all those who asked,
EarMen Sparrow balanced 2.5mm TRRS standard
First, let me state that when this little device works properly the sound coming out of the balanced output is exceptional.
But unfortunately I have been having a lot of issues with the sparrow. When using on iPhone 12 with Lightning to USB Camera Adapter, static/crackling sound makes it impossible to listen to. EarMen’s CS replied to my complaint with this statement: Our recommendation is to keep Sparrow away from your phone and use shielded GND USB C cables at least 50 cm long.
Adding a 50 cm cable to a portable unit that should work with your smartphone kinda defeats the purpose of buying this thing for, you know, it’s portability factor. None of these crackling sounds appear when using on an iPad Pro.
However, when I pair them with a pair of Final Audio E5000, I need to plug in the Earmen labeled USB c to c in first, wait until the sparrow is turned on after blinking lights and then plug in the earphones cable (in this instance a 2.5 balanced cable) in order for them to be appropriately amplified. This also occurs with other earbuds (who are easier to drive) I own. The difference is night and day. Does this happen to anyone else? A portable device like this should be plug in and play IMO.
Every 30 minutes or so when listening from my IPad Pro, the sound would suddenly stop coming through and then play the audio completely distorted. Plugging the DAC in and out of the USB c input of the iPad resolves this. But again, this is not a pleasant experience.
EDIT: when listening from the USB C to USB A into USB Camera Adapter Lightning to iPhone 12 I also receive the message ‘accessory uses too much power’ as seen in the screenshot attached.
Maybe this is why the Cobalt, which only has a 3.5 mm output, with similar specs, arguably worst build quality but seamless workflow on any operating systems costs 100usd more?
I received an email from Earmen’s customer service saying that all issues would be resolved if I upgrade the DAC. However, I only own Apple devices and the FW upgrade can only be done on windows 10. It is not easy to find someone/a stranger with a windows laptop who will allow you to plug in a flash drive-looking device, especially during a pandemic.
I really hope Earmen get their stuff together, replace/refund all defect units or I find someone with a windows computer and the FW update resolves all these issues because boy when this thing works, it kicks ass!
