Just do some research, yeah the Shanling M0 could work. It have BT to USB output.Maybe shanling mo m1 or hidizs ap80 can do that...
E1DA DACs Discussion Thread (PDV2, 9038S, 9038D, 9038X, HiFiToy, HPToy)
- Thread starter Tysun
Tysun
You are better off with ES100. It has a capable BAL out with LDAC.Is it possible to use any of e1da with bt receiver? I want to stream LDAC from mobile phone(mostly from tidal) to some bt receiver and then to e1da device?
Maybe phone -> LDAC -> FIO BTR3 -> Type-C cable -> E1DA 9038S -> 2.5 headphones?
Tysun
9038S and (upcoming)9038D has moderate batt consumption (90mA idle) which is actually less than other dongle DACs. Operating current depends on your volume/HP impedance but a good 4~5 hrs at least from smartphone should be no problem.Will there be a Low battery consumption version be made? I don’t mind lesser power as Long can drive a 1xx dB iem
but ES9038Q2M is a way better then AK4375aYou are better off with ES100. It has a capable BAL out with LDAC.
Tysun
Don't judge a DAC by only its model number. ES100 has gotten much praise.but ES9038Q2M is a way better then AK4375a
Or Fiio Q5S. I really don't know any BT receiver with USB out. Doesn't make sense for the manufacturer to produce one.
Hal Rockwell
Contender 1 has arrived: Meizu HiFi DAC Pro.
Waiting to be challenged by Contender 2: E1DA 9038D!
Wait, why does it look different from the official photo? did I buy the wrong model....?!?!
Official photo:
OK I think I have bought the non-pro version. Did not know there were 2 models available and I thought they were on sale at 29.90..... pffff. My bad.
BUMMER.
meizu non Pro: CS43131, no OPA spec stated, just "16-600Ω self adaptive impedance range"
Meizu Pro: Same DAC, same SNR/DNR/THD+N. Only difference is OPA spec stated "OPA1622". probably thats the only difference for charging $20 more.
From the official Chinese MEIZU store:
NON PRO VERSION
PRO VERSION
Those products are very confusing. I wish that someone would compare the both of them. Their specs are the same, so I don't know what the addition of the OPA1622 brings to the table.
Something doesn't add up.
CS43131
OPA1622
According to the MEIZU, the specs given on both of the products is of the regular version, since the PRO version must have much bigger output power due to the use of the OPA1622, unless it's used as a buffer for some reason.
Tysun
Exactly. My bad, I only thought there were one version before I received mine and realised I was a noon, did not check out more info about it before ordering. Yes something is fishy. Why even with OPA1622 the specs are exactly the same? Weird.From the official Chinese MEIZU store:
NON PRO VERSION
PRO VERSION
CS43131
OPA1622
Hal Rockwell
The PRO version is supposed to be a China only product since it's only posted on the Chinese MEIZU website.
The Shanling M1 does USB output when used as a BT receiver, I'm pretty sure the M0 does as well.
Krassi
FYI
Hiby R3 is not crap a muddy fogcanon anymore and i can plug this combo on the back of any small or big DAP that spounds like crap
really you can have your 9038s alien facehugger on the back of any dap )
seeya Daniel.. ill stick the 9038s with velcro tape on the back so that i can remove it whenever i like..
Krassi
Test it tomorrow in an IKEA shopping frenzy and this will keep me alive !
FYI
Hiby R3 is not **** a muddy fogcanon anymore and i can plug this combo on the back of any small or big DAP that spounds like ****
I do the same but my cable is long. Can you give a link where you got that nice short cable?
Krassi
yep this one and the 90 degrees adapters are the same OEM thing you get wherever you look.
https://www.ebay.com/itm/Cygnett-Lightspeed-Usb-C-To-Usb-C-Geflochten-Kabel-Kurz-Schwarz-10cm/153520396126?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20170511121231&meid=ed10a2af883c4c4b8d52fd4b0d6a5f25&pid=100675&rk=5&rkt=15&sd=143300891824&itm=153520396126&pmt=0&noa=1&pg=2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci:69b5acf2-ec7a-11e9-bcd5-74dbd1807992|parentrq:bd09fd0b16d0a9c9a877169fffe50406|iid:1
this plus 2x 90 degree adapters and your ready to go..
Krassi
oh by the way tried it and it works.. sundaras at 100% running on hiby r3 are loud enough!
sick
sick
Tysun
Lovely =)oh by the way tried it and it works.. sundaras at 100% running on hiby r3 are loud enough!
sick
