Shane D
You are a wealth of information!As far as I'm aware, Fostex uses a proprietary connector at the cups that you won't find on any other brand (at least in regards to dual-entry cables). Monoprice uses 4-pin MiniXLR connectors at the cups, which while not proprietary, nobody else does it. Plenty of headphones (Audeze, AKG, etc) use 3-pin MiniXLR connectors, Monoprice went 4-pin for unclear reasons.
The dual 2.5mm like on the Teaks is also not proprietary, but is uncommon. Hifiman used to use dual 2.5mm until they switched to dual 3.5mm, although Hifiman use/d 3-pole (TRS) connectors, which were wired in a way that would be incompatible with the Teaks. I think it's a similar story with the Oppo PM-1. Same connectors, different wiring.
A way to circumvent any dual-2.5mm incompatibility is by looking for cables that use 2-pole (TS) connectors. This would maximize compatibility to work with, to my knowledge, any dual-2.5mm headphone. And I've found that the easiest way to find cables with dual-2.5mm connectors, TS-style, and readily available without needing to commission something custom, is by looking for Senn HD700 cables. Seems to be the most common cable that ticks all the boxes. The shape of the male connectors is slightly unusual because the HD700 has recessed female connectors, but the shape doesn't interfere with not-recessed female connectors like on the Teaks.
I had forgotten about the mini-XLR's on the 1570's. But they were wired differently and I couldn't use them with my (Hart) Audeze cable and had to get a special cable made.
I guess it was only the Fostex TH610's that I used to think looked like a Sennheiser cable, but wouldn't play nice together?
I guess if I decide to grab some E-MU's, I will need to be careful on spec's.
Thanks for the education! Nearly daily learning on Head-Fi.
